| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Any tips on removing the aluminum heatsink from a PII processor? The heatsink looks to be mounted using 4 screws with special type of star socket-head. I tried drilling through the screws but the heatsink is still tightly connected? Could it have been glued?
#2 |
Is it a slot1 CPU?
Picture? /Hugo |
#3 |
#4 |
i think i did what you're trying to do before, just can't remember if it's a PIII or PII slot 1
you have to use a flathead screwdriver to separate the main heatsink to the thin piece of aluminum plate directly attached to the core, i think intel used some thermal paste and the screws that you already drilled to stick them together goodluck, onixuser |
#5 |
I did this a few times and I remember having to take off a couple of clips, the kind that you have to squeeze and pull through.... But it was too long ago for me to be able to explain the whole procedure.
#6 |
Passive sinks are often glued with thermal epoxy stuff. Try sticking it in the freezer for 15 minutes or so, to make the epoxy brittle, then with a flathead screwdriver gently try and pry it from the cpu.
I could be totally wrong about it being glued though |
#7 |
Thanks for the tips. The Pentium II is a Slot 1 processor with a very nice aluminum heatsink.
I will try sticking them in my freezer and seeing if that breaks the seal of the glue/epoxy. |
#8 |
Warp Engineer
On Holiday
The slot 1 PII had 2 retention clips that have to be removed before you can separate the assembly. A pair of needle nose pliers usually works well.
- Dan |
#9 |
I'm not really sure about a Pentium II specifically, but often the heatsinking compound paste that is used for these things will dry out after a few years and really need a bit of force to get off. You might need to use a lever of some sort.
#10 |
A heat gun helps for that, thevoice.
| Overclocking CPU's (split from Pentium -vs- AMD Athlon) | sagarverma | Everything Else | 11 | 15th February 2006 03:12 PM |
| Pentium -vs- AMD Athlon | OMNIFEX | Everything Else | 66 | 14th February 2006 04:20 AM |
| PC processor copper heatsink for amp cooling ? | Bernhard | Solid State | 5 | 18th December 2005 01:20 AM |
| dB loss by using passive crossovers? Active vs Passive and 1st vs 4th order | Hybrid fourdoor | Multi-Way | 3 | 11th July 2004 09:16 PM |
| Page generated in 0.10447 seconds (79.04% PHP - 20.96% MySQL) with 10 queries |
