Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 13th March 2005, 12:28 AM   #1
Default salvage transformer ideas
I have this large EI transformer I'm hoping someone could suggest uses for.
115V 16 guage primary
30V 16 guage x 3 dual secondaries
70V 24 guage secondary
The laminations are 4.375" x 5.25" stacked 4" thick.
Weighs about 30lbs.
Any guesses about its VA rating?
Thanks.
Old 13th March 2005, 02:30 PM   #2
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Awfully thick core.
3 x 30V @ 16AWG ~= 5A per = 450VA + 70V 24AWG = 1A = 70VA, total = 520VA.
115V @ 16AWG = 5A = 575VA, close enough.
Tim
See my Electronics webpage -- the home of Vacuum Tube Drag Racing.
The key to being a successful Audiophile: "I reject your reality and substitute my own!"
Old 13th March 2005, 06:43 PM   #3
Thanks. Only problem is that it buzzes a bit.
Old 13th March 2005, 07:19 PM   #4
frugal-phile(tm)
planet10's Avatar
That comes real close to the 20VA/pound rule-of-thumb (ie 600VA)
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 13th March 2005, 07:24 PM   #5
I weighed it outside of the chassis and it's actually 25.5lbs. So I guess about 510VA?
Old 13th March 2005, 07:53 PM   #6
Sch3mat1c's Avatar
You can also calculate approximate VA capacity by core dimensions: if a wasteless cut, the center limb is 1 3/4" wide, and stack is 4" you say? That's 7 square inches, and according to a booklet I have, W = (5.6 * A)^2 = 1.5kVA... eh, maybe not! That book makes too many assumptions. Clearly it doesn't work with such an obesely stacked transformer.
Which reminds me, they used to do that for 25Hz transformers (i.e., use a given transformer design for whatever radio, and stack up the transformer and windings for the lower frequency models), but that it has the heavy wire suggests otherwise.
Tim
Old 13th March 2005, 07:54 PM   #7
Sch3mat1c's Avatar
Oh, and note you can easily draw 1 or 2kVA from it -- IF the insulation can tolerate the temperature rise and your circuit can tolerate the voltage droop.
Tim
Old 13th March 2005, 07:56 PM   #8
The transformer is from a 28VDC 18AMP continuous power supply that my employer was throwing out. I don't know what I'll do with it. I just wanted the chassis and heatsinks.
Old 13th March 2005, 09:34 PM   #9
frugal-phile(tm)
planet10's Avatar
Well that is 504VA by itself...
dave
Old 15th March 2005, 09:20 PM   #10
megajocke's Avatar
28VDC 18AMP?
If it is a linear supply that would men 18A from the filter bank. Most formulas suggest using a transformer with Iac = 1.8*Idc in bridge or Iac = 2*Idc if using full wave with center tap. If that formula was used in this one...
1.8*18=32.4
32.4*30=972
So something like 1000VA. Nice.
Even if it isn't that much, I would have used it in an amp, something like 4 channels of 80W/8ohms. It would probably have no problems doubling that into 4ohms either with that transformer...
Salvage component from an old amp ? NyxOne Chip Amps 9 26th July 2011 11:31 AM
Salvage value? Mark2727 Class D 9 13th April 2009 05:32 PM
Parts Salvage jkeny Digital Source 2 21st April 2006 04:10 PM
Help salvage my old reciever? xstephanx Everything Else 7 25th March 2005 01:08 AM
Can I salvage this component? TheDarkside Parts 1 13th November 2004 04:59 PM
Page generated in 0.10220 seconds (77.40% PHP - 22.60% MySQL) with 10 queries
