| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Guys/ Mark,
I just got the Tek 7633 Storage Oscilloscope. POwering up it displays a squiggly line with no probes hooked up. Even after hooking up the probes, the lines stay even if I ground the probes. The modules work fine with my 7904 scope... could it be the seller sold me a bad 7633? |
#2 |
Second pic.
#3 |
Looks like no deflection. Beam parked in middle of screen. The smear is interesting .
#4 |
English please....
Is this a calibration issue or is the unit defective? More info: The squiggly lines stay as is even after removing all plug-in modules... |
#5 |
Does the beam move across the screen at all ?
#6 |
Just stays there and fluctuates.... flickers....
#7 |
Deflection circuits pull the beam from left to right (horizontal deflection) . GENERALY when the beam is stuck there is no deflection.
there usualy is a beam finder button you push and it will just display the beam with no deflection . I dont think it is a calibration issue >. |
#8 |
So basically the delfection circuit is bad. Becuase I pressed all buttons, on one, it narrows a little but is still flickering all over.
#9 |
try cleaning the horizontal and vertical rotary switches .
horizontal has the time base ms vertical has the voltage |
#10 |
Are these modules form your 7904? If these came with the scope then the sweep module may be bad. You can take one of the sweep midules from your 7904 and use it in this scope to see. The good thing is that the on screen readout is working and thats a sign that the deflection circuits are working....were they not then there would be no readout...... I suspect the mainframe is good and the sweep midule(on the right) is bad. How do you have the controls set...... both on the mainframe and on the sweep module?
Mark |
| Great deal on Digital scope. Is this enough scope? | hifimaker | Pass Labs | 1 | 1st May 2007 09:59 PM |
| Wanted: Your Defective USB 1 Cable | valveitude | Swap Meet | 6 | 21st December 2006 05:27 PM |
| defective playstation - need help | maps | Digital Source | 0 | 26th February 2006 09:44 AM |
| Do I have a defective RIAA? Opinions, please! :D | miksin | Analogue Source | 2 | 20th December 2005 09:45 PM |
| Page generated in 0.09171 seconds (80.11% PHP - 19.89% MySQL) with 11 queries |
