| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
#21 |
Better pic:
#22 | |
Ok here 7a26 on left, and sweep on right, oddball comparator left out. same %@%
#23 |
Nope, couldn't get mine to do that sort of trace at all. Possibly may be a bad sweep amplifier but with the on-screen display working fine that would be hard to fathom.... perhaps one of the power supply caps or regulators are shot. There are quite a few regulated supplies in that scope. The power supply is in the back. I would suggest going over to TEKSCOPES forum at Yahoo. There are quite a few ex-Tektronix service engineers that moderate that board and they will be able to help you for sure..... With a little luck someone there may be able to e-mail you the manual in PDF form if you don't already have it....... If you do start checking power supply test points.... none of them should be more than a tenth or two off, some are more tightly regulated than others. You could also use your 7904 to check for excessive ripple but be careful where you go stickin that probe...watch the max DC input rating and use a X10 probe!
http://groups.yahoo.com/group/TekScopes/ Photo shows the verticle amp on the side and the horiz on top. Yours is a later scope and may have a blown power amp I.C.. Mine has a discrete amplifiers whilst the later scopes have power op-amps. Many parts can be had from this link...... Walter is a real nice guy and if he doesn't have what you're looking for he will more than likely refer you to someone else...... http://www.sphere.bc.ca/test/index.html Mark |
#24 |
Ok ,
Thanks guys! |
#25 |
Actally its doing more than it was. Obviously its sweeping the beam across but there is some sort of noise or fast imbalance in the vert. amp and that may be where the problem lies. Let me know what you find out...... If you can't repair it I may be able to.
I blew up your photo.... Is the top left button pushed in...... that selects that left hand vert. module...? Mark |
#26 |
Looks like the fault is in the LV power supply. The 76xx series tend to have problems with the electrolytics caps , so 50/60 Hz (cps) hum goes into the circuits. So I'd recommend you check for caps.
hth, Andreas |
#27 |
All caps or the ones in the PSU?
thanks. |
#28 |
#29 |
Danka Tekman!
#30 |
Thats exaactly what I was thinking. If the supply is similar to the 7704A supply then the two 550uf @ 200 volt caps would be the first to check. They were bad in my 7704A as it had quite a bit of ripple in the trace when I got it. I've been told by retired tektronix techs that they were a bit of a problem in those scopes.
Next check the rest of the smaller amumnuim electrolytics and all the regulator transistors. |
| Great deal on Digital scope. Is this enough scope? | hifimaker | Pass Labs | 1 | 1st May 2007 09:59 PM |
| Wanted: Your Defective USB 1 Cable | valveitude | Swap Meet | 6 | 21st December 2006 05:27 PM |
| defective playstation - need help | maps | Digital Source | 0 | 26th February 2006 09:44 AM |
| Do I have a defective RIAA? Opinions, please! :D | miksin | Analogue Source | 2 | 20th December 2005 09:45 PM |
