Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 12th March 2005, 02:39 AM   #11
Looks like the problem is that you have the sweep module plugged into a verticle amplifier slot! Put the sweep module into the right slot and a vert amplifier into the left slot. Not sure what that other module you have on the left is. With my scope I couldn't get any response with the sweep module plugged into the center slot. shown in the next photo. I have 2- 7A26 vert. modules and one 7B53 sweep module in my scope.
Mark
Old 12th March 2005, 02:41 AM   #12
Shown with the sweep module in the center slot.......
Old 12th March 2005, 02:44 AM   #13
These things are really works of art inside! I ought to buy a few just to frame and hang on the wall .
Be sure to keep your intensity down till you get it working... burn't phosphor is nasty.....
Mark
Old 12th March 2005, 02:53 AM   #14
tenderland's Avatar
Default scope
Well I gues im all wet . Did it work when you switched the modules ?
It still seemed that there was no horizontal deflection from the picture
Old 12th March 2005, 02:56 AM   #15
K-amps is offline K-amps  United States
K-amps's Avatar
It never worked when I got it.... Let me switch the modules and let you know.
Old 12th March 2005, 02:57 AM   #16
K-amps's Avatar
Originally posted by Mark A. Gulbrandsen
Are these modules form your 7904? If these came with the scope then the sweep module may be bad. You can take one of the sweep midules from your 7904 and use it in this scope to see. The good thing is that the on screen readout is working and thats a sign that the deflection circuits are working....were they not then there would be no readout...... I suspect the mainframe is good and the sweep midule(on the right) is bad. How do you have the controls set...... both on the mainframe and on the sweep module?
Mark
7904 modules seem to work fine. I switched the 7633 7A26 and it worked in the 7904. More in a sec
Old 12th March 2005, 02:58 AM   #17
Yea, put the 7A26 in the left compartment nd the sweep in the right compartment. Leave out that odball module till we figure out what it is...... I saw that scope on E-Bay...... Do you have a link to that auction?
Mark
Old 12th March 2005, 03:02 AM   #18
K-amps's Avatar
Ebay link:
http://cgi.ebay.com/ws/eBayISAPI.dll...877983194&rd=1
same flicker, even with all 3 modules out .... mainframe only
Old 12th March 2005, 03:04 AM   #19
Let me see if I can replicate that on mine. You're not in the storage mode are you? You need to be in standard display mode.... Back in a couple......
Mark
Old 12th March 2005, 03:06 AM   #20
K-amps's Avatar
I have it storage off:
see without any module
Great deal on Digital scope. Is this enough scope? hifimaker Pass Labs 1 1st May 2007 09:59 PM
Wanted: Your Defective USB 1 Cable valveitude Swap Meet 6 21st December 2006 05:27 PM
defective playstation - need help maps Digital Source 0 26th February 2006 09:44 AM
Do I have a defective RIAA? Opinions, please! :D miksin Analogue Source 2 20th December 2005 09:45 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
