Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 4th March 2005, 05:36 AM   #1
neutron7's Avatar
Default PSU sharing grounds
I have 2 switching type power supplies, one is 12V 12.5A and the other is 5V 10A
i want to use them together to power a small motherboard which only requires 12 and 5 volts. it is for a small totally fanless PC
i was thinking of just powering them up and making sure there is no voltage differential between the 2 grounds before connecting them together is that enough to make sure it is safe? otherwise i could use a regulator off the 12V one, but i would prefer not to.
Old 4th March 2005, 06:26 AM   #2
Ivo_Hristev's Avatar
Hi neutron,
Try measuring the resistance between the two grounds.
Old 5th March 2005, 12:23 AM   #3
BlackDog's Avatar
Originally posted by Ivo_Hristev
Hi neutron,
That normally works just fine.
When I do this, I usually connect a 10ohm resistor (to limit the current) between the two and measure the current flowing.
Steve
Sharing gainclone PSU with other circuits rockgardenlove Power Supplies 6 7th January 2011 04:21 PM
Just sharing my 26 experience last night... arnoldc Tubes / Valves 22 18th July 2007 01:15 PM
Current-Sharing on the DOZ Amp EchoWars Solid State 9 3rd November 2004 01:20 AM
sharing amplification chanvr6 Solid State 0 4th July 2004 10:09 AM
Sharing DAC outputs Prune Digital Source 0 22nd January 2004 10:40 AM
Page generated in 0.06591 seconds (70.47% PHP - 29.53% MySQL) with 10 queries
