| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
The mid-range has a cracking sound when I play certain classical music.
What could be the problem and how much would that cost? Sorry I don't know much about speaker technology, but I'd like to get them repaired. But since this model is discontinued, every repair place I've called is trying to rip me off. First with a $25-$75 cost just for an estimate. I've never had speakers repaired before and aren't sure what to expect. Tips would be great. Thanks guys. |
#2 |
you dont say what that certain classical music is, now if it's the cannon shots on the 1812 overture then it more than probably is the voice coil former hitting the back plate of the magnet a safety/ warning feature built in by kef to warn you that the unit is being overdriven possibly into b200 unit used in the 104 abas well as its smaller sibling the b110 which l used in a 3 way daline and used to bottom out regularly resulting in a loud "crack", so for safetys sake back off the volume a little as replacement b200's are expensive and difficult to find , not sure if kef still makes them or has stocks at all cheersTC
we all have problems only some people have more than most.... long live the Magyar (Hungarians) in the world! |
#3 |
Thanks bro.
But the volume actually isn't through the roof. I don't know how else to describe volume, but it's at comfortable levels for baby ears and senior citizens alike and definitely below volumes at the movie theaters. So would your assessment be any different? |
#4 |
One more thing... so far, I've heard the cracking
sound w/classical piano and horns. Modern music and regular talk radio seem unaffected. |
#5 |
darn-- I forgot to mention that only one of the two towers
have this midrange problem. The midrange in the other tower is perfectly fine. In other words, all other speakers in the two towers are fine. |
#6 |
Did it Himself
Maybe with age the voice coil has come loose or the former got deformed by heat/age?
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#7 |
Did You should attempt to exchange midrange drivers.If after swapping the mid drivers the crackling moves to the other channel, then you probably have a damaged part in your crossover.That should be fairly easy to fix. RC
#8 |
i replaced one of my B110's with an Audax 5 1/4" unit -- the B110's and B200's do show up for sale every once in a while.
#9 |
frugal-phile(tm)
Is it just the one mid on one side, or both?
From the experience of one of the fellows on the IMF list, KEF was doing B110 recones as recent as within the last year... not cheap thu. If you were really anal you'd get all 4 done). I don't think the 104/2 uses the commonly available B110... finding a used replacement would mean someone is tearing a set down for parts. dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#10 |
no the 104ab used the b200 with a similar voice coil arrangement to the b110 is all l meant to say in my previous post...... cheers TC
| monsoon planar computer spkrs | capt mike | Planars & Exotics | 4 | 29th July 2008 09:05 AM |
| What to do with Yamaha spkrs | jackinnj | Multi-Way | 2 | 20th December 2006 01:41 PM |
| Most suitable amps for bi-amped OB spkrs | ozziozzi | Solid State | 3 | 9th July 2006 12:18 PM |
| whats with the hihgh $$ for retail spkrs? | aarono | Multi-Way | 14 | 27th March 2005 04:00 PM |
| what do i need, pc to home theater spkrs | theturtle | Everything Else | 7 | 18th November 2002 09:14 PM |
| Page generated in 0.11108 seconds (83.85% PHP - 16.15% MySQL) with 11 queries |
