Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 27th February 2005, 04:28 PM   #1
Atic is offline Atic  Portugal
Default Amp volume
Last summer i started learning a bit of electronics. Now im trying to find how to control the amp power. The effect i pretend is a volume button cuse im using the amp with a dvd, and the level 1 on dvd's volume is VERY loud. So i suppose i can control how loud it goes with a potenc. on the right place.
Anyone who could help i apreciate
Old 27th February 2005, 06:19 PM   #2
you can use a 2 gang potentiometer as a passive volume control without any electronics.
The input and output impedance are quite high using this method and with longer interconnects you will lose high frequency information.
Check the output impedance of your DVD player ( maybe about 1k ). the input impedance of your volume control should be about ten times this ( about 10k ). the maximum output impedance of this volume control will be just over 10k/4 (about 2k5).
If you use a 100k pot your output impedance will be about 25k.
Keep all your connections short (about 300mm to 600mm) and use coax for leads.
Look up passive preamp for more info. Start with elliot sound products.
regards Andrew T.
Old 27th February 2005, 06:30 PM   #3
Bill Fitzpatrick's Avatar
Pick up a second hand preamp and be done with it.
Volume control on DVD player remote. Lose resolution at low volume? Circlotron Digital Source 2 10th June 2011 07:20 PM
Box Volume is Box Volume, right? skooter Car Audio 5 4th November 2008 05:17 AM
set volume with 50k Pot on Zen V4 cHab Pass Labs 2 17th June 2008 12:49 PM
volume pot william1981 Solid State 5 25th February 2007 10:31 PM
Box volume eitanwaks Multi-Way 7 19th April 2005 02:45 AM
Page generated in 0.07160 seconds (74.31% PHP - 25.69% MySQL) with 10 queries
