Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
anyone ever used metalized polypropylene caps from Digi-key?
Old 26th February 2005, 08:10 AM   #1
crtubes is offline crtubes  United States
Default anyone ever used metalized polypropylene caps from Digi-key?
Digi-key is selling mkps from 3 manufactures:
Panasonic - ECG
BC Components
EPCOS Inc
MKPs from them are cheap. But there're rarely discussions about these caps. how do they sound compare to, let's say, the same cheap MKPs from Solen, Dayton, etc?
Old 27th February 2005, 10:11 PM   #2
wrenchone is online now wrenchone  United States
wrenchone's Avatar
The end terminations are very good on the Panasonic caps. If you get the right series, they are rated for low loss/high ripple current. I don't know how that translates to sound quality, though.
I'm currently using GE and Sprague low loss polypropylenes in my preamp, as I had them on hand. I haven't done any comparisons with other caps, though this preamp sounds loads more detailed than my old Nikko, which had about 5 electrolytics in series with the signal chain...
Old 28th February 2005, 01:44 AM   #3
gingertube is offline gingertube  Australia
Default Polypropylene Caps
The "Metalised" Poypropylene are what are commonly known as "Film" types. My experience is that as far as sonics are concerned the "Film and Foil" types are superior. Unfortunately the "Film and Foil" types are often not available in the higher voltage ratings (ie above say 400V).
On the subject of capacitors I have had very good results recently using Polyphenylene Sulphide (PPS). This is the dielectric which was introduced to replace Polycarbonate when it dissappeared from the marketplace BUT I feel that they are far better than Polycarbonate ever was. Especially good for paralleling electrolytics ro miantain high frequency behaviour. The other thing about them for valve circuitry is the 125 to 150 degrees C temperature rating. Once again ONLY available ro about 400V rating. Half the price of Polypropylene for at least 90-95% of its performance.
Ian
Old 28th February 2005, 04:41 AM   #4
Sch3mat1c is offline Sch3mat1c  United States
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
I've been wondering about them myself. How many volts of 50kHz do you suppose they could handle before melting?
Tim
Seven Transistor Labs, LLC
Projects and Resources / Electronic Design and Consultation
Old 28th February 2005, 05:33 AM   #5
I assume you mean the PPS - the short answer, to put it in the OZ vernacular is "DUNO".
The ones I use are Evox Rifa SMR Series. Check out their web pages.
Ian
Old 15th September 2005, 09:16 PM   #6
Joe Rasmussen is offline Joe Rasmussen  Australia
Joe Rasmussen's Avatar
Ian
Hi Ian
I am in Sydney. Where in Oz are you getting SMR caps? I am trying to find a local supplier, local as in Australia rather o/seas.
Joe R.
The "Elsinore Project" DIY Speaker System " & DIY "Trans-Amp" - 40 Watt Transconductance Amp
Soon: High Frequency Bias in Tube OPT - "Don't take anything I say as an affirmation but as a question."
Old 15th September 2005, 11:47 PM   #7
G'day Joe,
I bought mine from Farnell (small quantities so I was'nt fussed about paying the mark up).
One of the advantages to working for a big company is that I have access to tools like Australian Electronics Directory Plus. It tells me that the Oz importers for Evox Rifa are:
Connektron P/L,
Phone Sydney 9597-6411
Web www.connecktron.com.au
Ian
anyone ever used metalized polypropylene caps from Digi-key?Hide this!Advertise here!
Polypropylene caps liberty Parts 21 31st August 2009 06:04 AM
10 uF Polypropylene caps dsrjohn Parts 9 5th May 2004 01:30 AM
Where to get polypropylene caps with <2,5% tolerance in Norway? Alcaid Parts 5 23rd February 2004 08:54 PM
Precision polypropylene 1% caps - any good? peranders Parts 44 16th March 2003 04:31 PM
Copyright ©1999-2017 diyAudio
