| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I am a little confused by the value that i read on a capacitor. It says: 12500 MFD.
Well is MFD the same as micro farad (uF) or mili farad? I know that such a things are in the USA not always the same as in Europe. By the way, i am talking about a Mallory CG1252U75G1
Als er "X" artikelen benodigd zijn, blijken er "X" - 1 in voorraad te zijn. |
#2 |
It´s 12500µF
#3 |
Thanks a lot
#4 | |
If it was millifarad they would be 1000 times bigger, both as to value, but more importantly by physical size !
#5 |
m = milli, M = mega 12,500 megaFarad, wow thats big. The CAT tried to roll it into the garage but it would not fit through the door opening. You think the manufacturers could at least try to get their labelling right.
regards Andrew T. |
#6 |
Hi Andrew. I'm not sure of two things. (a) Just how much you are joking and (b) whether you are actually right about the use of "m" and "M" in the way you have just indicated. Is that an accepted convention? I've functioned for several decades on the basis the "u"(well the Greek "u" actually) "m" or "M" were pretty much interchangeable in this pariticular context and haven't got into serious trouble yet. Or am I just being humourless? (if that's the case I've got problems that this forum won't fix)
"It was the Spring time of the year when aunt calls to aunt like mastodons across the frozen waste." P.G. Wodehouse. |
#7 |
I am part joking but also on my hobby horse re correct nomenclature. In the metric system all the capital letters are reserved for multipliers greater than 1000 and all the lower case for multipliers less than or equal to (<=) one. ie. k =*1000 m=/1000 etc.
regards Andrew T. |
#8 | |
What is confusing about that ? If its a special computer grade the letters are CGS. Mallory code even gives you production shift numbers, production date, and capacitor size ! m and M are not just metric symbols. They are part of the International Standardisation units(SI) ! Sorry Jonathan.
Looks like Sponge Bob has killed another thread. |
#9 |
Talking about capacitors, I have never seen any manufacturer express capacity in milifarads.
As jacco said Mallory always mark their caps with MFD (micro). I thing Sprague is doing the same. I preffer using uF and most European shematics and caps are marked with an u. |
#10 |
If you can lift it without back strain, it's not "milli-" . If you can lift it without a forklift, it's not "Mega-".
An overstatement of course, but you get the idea. And yes, the interchangability of "mu", u, m and M in this context is annoying. Like I don't have enough problems already nomenclature that may or may not omit nano on the way to pico.
| Confusing about grounding, please help | goldkenn | Chip Amps | 5 | 21st August 2008 04:20 PM |
| confusing transformer connections | audio_moksha | Tubes / Valves | 0 | 13th March 2008 03:07 AM |
| WE310A, a confusing issue | Kenneth Zhu | Tubes / Valves | 1 | 9th December 2006 02:24 PM |
| a resistor in input circuit is confusing me | john-china | Pass Labs | 2 | 15th September 2003 08:27 AM |
| Page generated in 0.10361 seconds (78.20% PHP - 21.80% MySQL) with 10 queries |
