Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 22nd February 2005, 05:55 PM   #1
brsanko is offline brsanko  United States
brsanko's Avatar
Send a message via MSN to brsanko
Default 6 channel pot
does anyone know where I can find a six channel volume control to make my own home thater preamp. my dvd player has six channel outputs and built in DD and DTS processers so I basically need a six channel preamp with a remote control volume control. Any suggestions would be appreciated.
PASSIONN
Old 22nd February 2005, 07:08 PM   #2
UrSv is offline UrSv  Sweden
UrSv's Avatar
http://www.siliconchip.com.au/cms/A_30608/article.html
http://www.decibelhifi.com.au/prod10.htm
UrSv
Those who say it can't be done should not stop those who are doing it.
Old 24th February 2005, 11:39 PM   #3
brsanko's Avatar
Default sorry I wasn't clear
Sorry I wasn't real clear I mean't like a six channel pot that I could build a passive preamp around, to go with the amps I plan to build.
PASSIONN
Old 25th February 2005, 12:16 AM   #4
http://www.thel-audioworld.de/bauteile/regler/Potis.htm
Those are the only decently priced ones i found. There is a supplier in usa, builds them at almost three times the price as small series.
Problem with thel - they don't ship to overseas. I got them shipped through my parents in germany.
But - they are excellent - the pots, my parents as well
Old 25th February 2005, 07:46 AM   #5
Send a message via ICQ to apolon34
send a mail to familygate@tiscali.de
he has some alps in 6x10k log motorized at a low price
Old 25th February 2005, 08:52 AM   #6
A disadvantage of ganged pots is imbalance at high attenuation.
Some manufacturers try to select or trim tracks on their pots to improve their tracking.
BUT with multi-channel pots this may be either expensive or impossible.
The effect is that signals to different channels will sound off centre or in the wrong location at lower volumes and may change position as you adjust volume.
regards Andrew T.
Old 25th February 2005, 08:56 AM   #7
Look at pages of www.taiwanalpha.com
Old 25th February 2005, 08:57 AM   #8
JochenH is offline JochenH  Germany
you could also use a 6-channel microcontroller based relay attenuator which is controlled by a simple mono pot attached to the internal A/D of the microcontroller if you want to have a pot to control it. Or you can use two pushbuttons (up/down) and then can use a remote control for setting the volume. Unfortunately this solution is more expensive
Jochen
Old 25th February 2005, 08:58 AM   #9
reaction's Avatar
You can build a DIY 6 channel 12-steps attenuator using a cheap 6 deck switch - you will have better sound and tracking than any pot.
Old 25th February 2005, 09:03 AM   #10
12 steps is not enough ( typicaly 33 dB ) for silent night listening .
Creating 5.1 Multi Channel sound from 2 channel jenkrich Everything Else 5 1st September 2009 07:29 AM
4 channel conversion to mono 1 channel iUSERTLO72p Car Audio 24 25th October 2007 05:07 PM
HELP!: Channel volume very very low, other channel fine. harrisni Solid State 2 20th September 2006 11:10 AM
My 4 channel car Amp distorting on 1 channel (large pics) MikeHunt79 Car Audio 9 3rd September 2003 06:41 AM
Help quick! 4 Channel > 2 Channel? zmoz Car Audio 3 5th July 2003 08:48 PM
Page generated in 0.09422 seconds (76.84% PHP - 23.16% MySQL) with 10 queries
