Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 21st February 2005, 03:45 PM   #1
homer09 is offline homer09  Canada
homer09's Avatar
Question What's with removing the sleeve off caps?
I've sporadically seen in different finished DIY or upgraded amps/components, naked caps. The outer jacket was obviously removed purposely. What is the motivation behind this?
One example that comes to mind is Peter Daniel's finished Patek amp pictures on www.audiosector.com
Old 21st February 2005, 05:41 PM   #2
KBK is offline KBK  Canada
parasitic capacitance, I would suspect. ie, the unwanted kind. Electrostatic charge, etc. just a guess. The differences would be minor, at best, but..when you've taken care of everything else..then it's time to remove the sleeves.
Sometimes, think that grounding them..like grounding a speaker magnet system, might be the way to go.
Also, the smaller the energy level, in mass terms, in the context of the use of the given capacitor, the larger the effect of removing the sleeve.
"Never forget that only dead fish swim with the stream." -- Malcolm Muggeridge.
"Truth cannot be brought down, rather the individual must make the effort to ascend to it." -- Jiddu Krishnamurti
Old 21st February 2005, 10:16 PM   #3
Or it could simply be for looks. Peter's amp is not just a musical device, it also has artistic appeal too.
Old 22nd February 2005, 06:09 PM   #4
thomas997's Avatar
So you cant see the brand
ie. use cheap caps and remove the sleeve and it looks fancier and more expensive.
Just one reason.
Old 22nd February 2005, 06:21 PM   #5
SimontY is offline SimontY  United Kingdom
SimontY's Avatar
Send a message via MSN to SimontY
I removed about 50 sleeves from my Roksan Caspian amp's caps and resoldered them all in a little cloer. Can't say which change brought about the effect, but I definitely preferred the new sound.
Old 26th February 2005, 07:48 AM   #6
They look sexy when naked. And sound sexy too.
Fork vs. Sleeve Terminal Octal Sockets. wrenchone Tubes / Valves 9 11th June 2009 04:40 AM
RCA 12AX7A/ECC83 (NOS) - sleeve of 5 beeah Swap Meet 0 10th June 2009 02:25 AM
40 pcs IRF1010 HUFA75339 sleeve for sale gxenakis Swap Meet 2 6th May 2008 01:22 AM
removing HF damping pF caps for guitar PRNDL Tubes / Valves 3 24th March 2007 12:00 AM
RCA to XLR cable, where to connect the sleeve? klitgt Parts 12 24th February 2005 07:15 PM
Page generated in 0.07808 seconds (74.22% PHP - 25.78% MySQL) with 10 queries
