Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Help: how to design temperature control for heating mantle
Old 17th February 2005, 09:05 PM   #1
Prune is offline Prune  Canada
Account Disabled
Exclamation Help: how to design temperature control for heating mantle
I want to make a heating mantle (for lab use) as I'm too poor to buy one (after buying glassware, no $ left...). I got some 18 AWG nichrome wire and Zetex fiberglass loom tubing from eBay for the heater. Now, first of all I'm not sure how to calculate the length of nichrome to use as a coil, given a certain wattage I want, and some minimum length (so I can wind a large enough mantle). A complication is that the resistance of the nichrome is a function of its temperature. My goal is maximum output of at least 300 W (500 W is better) and a coil that will fit in one to three feet of the fiberglass (no problem in having, say, a couple of loops in parallel).
The other thing I need help with is how to adjust the output. Some use variacs, but my goal here is to save money. Finally, I'd like to use a thermistor based temperature probe to control the thing. I plan to run it directly off the mains (so I don't have to get a transformer).
So, how do I do this? I could use a dimmer from a lamp for control, but then I can't automate it with a temperature probe. Please guys, help me out here.
BTW, will nichrome interfere with a magnetic field? I plan to DIY a magnetic stirrer that will sit under the mantle. It may be a problem if it keeps moving the coils.
Old 17th February 2005, 10:27 PM   #2
leadbelly is online now leadbelly  Canada
leadbelly's Avatar
I believe that the simplest circuit approach would be:
thermistor -> op amp -> potentiometer -> pulse width modulator -> opto-coupler -> triac
the op amp is to condition the thermistor input
the potentiometer is to act as a temperature setpoint by being a voltage divider so that you adjust the 0 to 1 transition of the trigger to the PWM
you need the PWM to cycle the coil
you need the opto-coupler to connect low voltage digital to AC
you need the triac to switch the "big" AC load
The whole problem with the world is that fools and fanatics are always so certain of themselves, and wiser people so full of doubts. Bertrand Russell
Help: how to design temperature control for heating mantleHide this!Advertise here!
"sensorless" soldering iron temperature control star882 Parts 6 19th January 2014 03:53 AM
Tube eq or tone control - how to design it? marz.tv Tubes / Valves 5 20th July 2009 12:01 AM
I have a pair of JBL control 5 speakers, which valve amp design you recommend? ultrapato Tubes / Valves 4 21st July 2005 03:25 AM
New IR Control Design Algar_emi Solid State 33 29th August 2004 01:16 AM
Temperature control Prune Everything Else 0 7th March 2004 09:54 AM
Copyright ©1999-2017 diyAudio
