| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Folks,
At risk of introducing something utterly germane to audio (grin!) I thought I'd ask a couple of questions about these modern marvels everyone talks about, Auricaps. I need some good caps for inputs and outputs. Because the circuit I have is exceptional, the caps must match. Anyone tried these? And does anyone have any idea where to get 'em in quantity at prices which won't make a grown man blanch? '.....where due to a tragic miscalculation of scale, the entire battlefleet was swallowed by a small dog.' I need 1uF 200V. Thank you in advance, Hugh www.aksaonline.com |
#2 |
There were at least 2 threads dealing with caps:
Black Gate Capacitors are JUNK Are Hoveland caps really worth the price? Some people mentioned Auricaps there. When you get them, let us know how they compare to Hovlands.
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#3 |
diyAudio Moderator Emeritus
Hi Hugh,
Don't know if these would make a "grown man blanch", but there here: http://www.partsconnexion.com/catalog/capacitors.html They are in the Toronto area (That's Canada, ahh), Rodd Yamas***a |
#4 |
Hugh,
The best place to buy Auricaps in quantity is probably direct from the manufacturer. Their website has pricing information for various quantities; 1uf 200v is under $9USD for 1, half that for qty 50. Take a look at Audience Auricaps Greg H. |
#5 |
If you're looking for matching caps, it looks as if Auricaps are not the ones for you-- 10% tolerance. If you get a big batch you could match them yourself, of course. It's strange that they don't tell you what goes into their caps... I guess some sort polymer and foil.
#6 |
My thanks to all who have responded.
My first port of call for any tech information is always DIYaudio, since there are so many helpful and knowledgeable people here. It's a little humbling, actually! Cheers, Hugh www.aksaonline.com |
#7 |
Hugh,
alternative suggestion: the Siemens/Epcos MKV B25839, 1µF/900V. They are about US$10 each. They tore any other cap into pieces on direct coupling cap comparison. Including Hovlands. Including fancy MIL Teflons. Search the forum to find my raves, no need to repeat that. If you then pester me enough, i ship them to you.
Greets, Bernhard |
#8 | |
#9 |
Hi Bernhard,
Thank you very much - I will investigate your raves, and maybe get back to you. I'm limited somewhat in space. Around 20mm x 16mm cylindrical would be the max. How's your amp coming along? Any listening impressions? Cheers, Hugh www.aksaonline.com |
#10 |
Hugh,
MKV 1µ: dia 20mm, length 75mm without leads, axial leads. Or you take 2x µ5, in ||, the you have 43mm lenght, same dia. The MKV is definitely worth making a nu layout AKSA: if the thing is built, i tell you 1st. At the moment i am drowning in other duties. Tonearms and diyAudio. Poweramp: after ASKA. Preamp: after poweramp. One after the other ... like the devil fetching peasants.
Greets, Bernhard |
| FS: (4) .01uf/600V Auricaps | mrdon | Swap Meet | 11 | 13th October 2008 04:17 AM |
| Are these the right Auricaps for Trends amp? | sdk | Class D | 2 | 2nd June 2008 07:27 PM |
| has anyone used auricaps and BG on their aleph 1.7? | jarthel | Pass Labs | 10 | 29th December 2007 02:14 PM |
| Large value Auricaps | Prune | Parts | 0 | 1st February 2004 04:09 AM |
| Auricaps | Positron | Tubes / Valves | 6 | 19th November 2003 02:38 PM |
| Page generated in 0.11592 seconds (82.07% PHP - 17.93% MySQL) with 11 queries |
