| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
diyAudio Moderator Emeritus
does anyone know of a good N-channel FET that meets or exceeds these requirements:
1) Qg (total gate charge) less than or equal to 50 nC 2) Rds less than or equal to 50 mOhms 3) low Crss 4) at least 40V rating 5) at least 1A continuous rating (higher rating preferred) 6) low power dissipation, 5W max 7) must be in a package i can use with my breadboard (ex. TO-220) i've been searching the spec sheets on digi-key and haven't come up with anything. i heard a good one to use is the Si9410DY but i don't where i could get some that are in a package i could use with my breadboard. anyone have any ideas or suggestions? |
#3 |
the IRLZ44N has really good specs, but it dissipates too much power.
a transistor like the SI9410DY would be perfect, but i can't find them in a usable package. http://www.fairchildsemi.com/ds/SI/SI9410DY.pdf do you know where i could find one like that or something similar? thanks for the help Tim. |
#4 |
What do you mean it dissapates to much power? The power rating is how much it can dissapate without breaking, not how much it does.
#5 |
hmm. right you are Tim. i don't know why i was thinking that. i'll probably order a couple of those to try out. thanks again for the help.
| Step-by-step guide to building a speaker | Richy | Multi-Way | 5 | 5th August 2008 12:48 AM |
| stuffing Mileva: first timer step by step questions | schro20 | Full Range | 7 | 2nd June 2008 05:49 PM |
| how to make spherical wood horns, step by step | angeloitacare | Multi-Way | 0 | 29th May 2007 01:50 AM |
| Using Step Up /Down Voltage Converter? | RogerWilco | Solid State | 1 | 2nd June 2006 02:47 PM |
| DC-DC step-up converter | sasha | Everything Else | 10 | 1st March 2004 08:12 AM |
| Page generated in 0.09016 seconds (71.70% PHP - 28.30% MySQL) with 10 queries |
