Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 11th February 2005, 07:05 AM   #1
Jye is offline Jye  Australia
Jye's Avatar
Question Where to get a 25 pin plug?
Hello,
I have a project at uni that calls for an array of electrodes and instead of making one I am hoping there is a plug out there I could use since this would be a lot neater and simpler solution. So I am looking for a male plug with 25 or more pins arranged in a square array e.g. 25 pins in a 5x5 square, any help in locating such a plug would be greatly appreciated.
PS I know there are plugs out there with lots of pins such as LEMO but I am after one in a square array.
Cheers
Jye
Old 11th February 2005, 10:56 PM   #2
wes-ninja250's Avatar
Square might be a little tough to find.. have you hunted through the Digikey catalogue?
I'd suggest using DB-25 if it's electrical characteristics are suitable; they are dirt cheap.
Old 12th February 2005, 12:41 AM   #3
jackinnj's Avatar
yeah, DB25 -- you can get the male and female connectors dirt cheap from Jameco or Digikey. there's an infinite variety of PCB mounted components. just make sure that the cables you use are "straight-through" --
you can use the older SCSI plug and jack with attendant cables -- the 50 pin types can just be doubled up -- the cables aren't difficult to find surplus. i use Hewlett Packard HP-IB (HP Interface Bus) which are always for sale on EBay.
Old 12th February 2005, 07:23 AM   #4
SCSI is also a good cable for many applications, having a much higher bandwidth than DB25 connector+cable. And if you have 25 signals, SCSI is perfect, because you can make every other pin (i.e. one row on your PCB) ground.
I haven't used HP-IB for anything, but I've used my fair share of IEEE-488 connectors. They're obsolete now, though; I'd imagine cables would be hard to find.
Wes
Old 14th February 2005, 01:55 AM   #5
Jye's Avatar
Thanks for the replies. Still haven't been able to find quite what I'm looking for so I guess the hunt continues.
Cheers
Jye
Old 14th February 2005, 05:26 AM   #6
Make ur own with machined gold plated IC bases
Gajanan Phadte
A plug for BSC and youtube ilewis33 Full Range 0 19th March 2009 04:05 PM
Adapter Plug Toddbo34 Parts 2 7th March 2007 08:01 AM
WTB: 2.5mm plug to 3.5mm plug cable Relax Swap Meet 5 10th February 2007 01:13 AM
plug for amp karma Everything Else 12 24th April 2004 08:53 PM
Page generated in 0.08168 seconds (74.46% PHP - 25.54% MySQL) with 10 queries
