Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 9th February 2005, 05:10 AM   #1
ble0t is offline ble0t  United States
ble0t's Avatar
Question Maintaining a constant output?
Given the fact that various sources have different output voltages that could range anywhere from 1V or below to 2.5V or above (if talking about unbalanced), how could one go about 'regulating' this to maintain a constant voltage no matter what voltage the source is outputing at?
This would obviously be in relation to a preamp with multiple source inputs. I am looking to avoid having to change the volume based on which source I am currently using.
Is there any simple way of doing this?
gravity always wins
Old 9th February 2005, 10:07 AM   #2
Best solution is to put attenuators for the high levels externally in the cables.
Other options like ALC presently found in walkmans (AVLC) will modify and deteriote the signal.
A good design could be a step attenuator with relays that does the job automatically by detecting the signal level.
LM 3914/15 can be used for this purpose as A/D.
Gajanan Phadte
Old 9th February 2005, 02:08 PM   #3
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Put a volume control on each. I do the reciprocal and have only controls for each, no switch; this allows me to listen to radio while playing computer games for instance. YMMV
You could also do compression, but this reduces dynamics, as it is supposed to do.
Tim
See my Electronics webpage -- the home of Vacuum Tube Drag Racing.
The key to being a successful Audiophile: "I reject your reality and substitute my own!"
Old 12th February 2005, 09:44 AM   #4
d3imlay is offline d3imlay  United States
Sounds like a nice application for a mixer.
Would it be nice to have constant current on the output transistors ? Bernhard Solid State 11 12th April 2009 12:31 PM
TDA7350 in bridge mode - sending constant 4V though output!?! minifly Chip Amps 2 12th March 2008 05:11 AM
Log potentiomenter, constant Rin borges Analog Line Level 2 13th November 2007 01:51 PM
Maintaining an 8 Ohm load/Book Reccomendation Dominick22 Multi-Way 1 10th January 2006 04:47 PM
Constant current PRBS Pass Labs 6 24th March 2002 12:49 PM
Page generated in 0.07829 seconds (75.23% PHP - 24.77% MySQL) with 10 queries
