| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Hi there,
I have just made a USB Sound card using a MAX4299 Stereo Amp and a PCM2900E Audio Codec. It didn't work properly at first, and whenever a sound was played a loud crackling sound would play, no matter what the actual output was supposed to be. After spending ages error-checking and using an oscilloscope to work out where the problem was, I got the card to work perfectly but only if I connected the analog ground of the board to the ground of the oscilloscope. As soon as a I disconnected the oscilloscope ground, all I got was the loud noise again. Does anyone have any idea why it would only work when attached to the oscilloscope ground, and if there is anything I can do to fix it? Cheers |
#2 |
You obviously have a grounding problem.
I take it you have amplified speakers. Are they by any chance grounded to the same ground as the scope? (I'll bet they are). If so, I would immediately check the connector where they plug into the sound card, and the wiring to the speakers. Wes |
#3 |
I presume you're using the +5v usb power for the board. Does the analog ground and power supply share the same ground wire? What happens if you use an external power supply?
For a different application i bought and used an isolated hub from these people. http://www.bb-europe.com/ |
#4 |
Thanks for the replies, turns out I had a 10R resistor in between analog and digital ground and that was causing the problem!
Thanks! |
| PC sound card sound chips | kaluchka | Chip Amps | 6 | 20th June 2011 03:48 PM |
| Which sound card? | MMeche | Digital Source | 1 | 28th June 2008 11:17 PM |
| mic for sound card | ostie01 | Multi-Way | 0 | 24th April 2006 06:28 AM |
| What Sound Card for PC T&M | primalsea | Multi-Way | 3 | 8th February 2006 02:08 AM |
| DAC/ Sound card | argonrepublic | Digital Source | 0 | 11th July 2005 03:39 AM |
| Page generated in 0.08141 seconds (72.84% PHP - 27.16% MySQL) with 10 queries |
