Tranformer question
Helo:) I have o short question.I have a 100 w transformer
220 v -> 2*48 v ca. I need to increase the voltage up to 58 v ca
There is no room to add any isolated copper wire in the secundary
so i have to take some out of the primary.So,the queston is how much i can take without causing damage in the long run to the transformer...i should take about 20% for 48->58 increase in voltage...The resistance of the primary is 32 ohms if it helps.
10x:)
thanks for the ansers...unforcentaly i can not use a secondary transformer because there is no space.....because what i do is restauration of an old amplifier+pick-up and i want to leave hin as close to the original as posible...there is no room:( As i read from the internet it is posible that the tranformer has a safety margin ..some transformers even have huge safety margins about 30% more izolated coper than the limit....i have no iddea how to test that..any good ideas apreciated..10x:)
