Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 7th February 2005, 02:14 AM   #1
Default Would you help ID this electronic component?
I am trying to identify this component, my brother thinks its a capacitor, but I dont know.
Its from a Electronic Automobile Dash cluster.
It's the black Barrel shaped can in the middle of the photo.
It has axial terminals on both sides, BUT is leaking slightly from both sides.
Is 10/16 inch long and 9/16 inch wide.
It has the # 0050 on the outside casing which appears to be a thick plastic material, both ends seem to be metal,no other ID other than the number.
Can you tell me WHAT this is, what value it is and I hope I can get a replacement from Newmark or Digikey
Thanks for your help
Robmeister
Picture included
Old 7th February 2005, 02:27 AM   #2
Bill Fitzpatrick's Avatar
It looks to me like a cap with a coil of wire wrapped around it. Why not take the plastic cover off and check.
Edit.
Looking again, I see L107 next to it. That might suggest a ferrite slug with wire wrapped around it since the "L" means "inductor" in electronicese. But then, a ferrite slug wouldn't leak so maybe it is a cap.
Old 7th February 2005, 02:33 AM   #3
rpapps is offline rpapps  Antarctica
Default Mystery Component
The code printed on the board next to it (L107) suggests it's an inductor or coil, probably wound on a ferrite core. Can't help with the value. Check for continuity with an ohmmeter. It's probably OK.
Cheers
Rob
Old 7th February 2005, 02:38 AM   #4
sivan_and's Avatar
Send a message via Yahoo to sivan_and
INDUCTOR !! Leak ?? may be some glue or soldering flux. ?...
See pic below...
SivanandBalan
Old 7th February 2005, 03:03 AM   #5
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Definetly an inductor. Probably barrel/dogbone/dumbell/whatever you want to call it shaped core, with some notches so the wire doesn't fall out. You can see the wire going up the side to one notch in the picture, as pointed out.
I don't know what you'd be seeing as leakage. Rosin, varnish or cement maybe?
Value might be 1 to 50 microhenries and looks to be around 0.5 to 2A rating. I can't tell very well from the pictures.
If it were failed, more likely the plastic casing (probably heat shrink material) would look warped, shiny (from being melted) or burned, depending. It would also smell distinctly burned...
Tim
See my Electronics webpage -- the home of Vacuum Tube Drag Racing.
The key to being a successful Audiophile: "I reject your reality and substitute my own!"
Old 7th February 2005, 08:54 AM   #6
wytco0 is offline wytco0  United Kingdom
I think it might be a battery, I have seen these somewhere else but I cant remember where.
Old 11th February 2005, 12:01 PM   #7
adx is offline adx  New Zealand
Originally posted by Sch3mat1c
Definetly an inductor. ...
Yes.
Old 11th February 2005, 02:31 PM   #8
sivan_and's Avatar
wytco0 wrote:
I think it might be a battery, I have seen these........
If so why it 's designated as L107?
SivanandBalan
Old 11th February 2005, 07:51 PM   #9
Default I put the board back in the vehicle
Thanks so much for your help,
After getting the consensus that the unit was not a leaking Cap, and that it was most likely varnish of some type that is on both sides. I placed the "inductor" back in the car after changing out some Surface Mount capacitors.
It seems to be working, so thanks again.
Much appreciated
Can you name electronic component shop(s) in Parma? agadis Parts 8 30th November 2007 08:54 PM
The Super Hiper Highly Ultimated electronic component... and you forgot it destroyer X Solid State 6 3rd August 2006 07:48 AM
Electronic component vendor in UK Volkerk Parts 2 27th December 2001 12:38 PM
Page generated in 0.10945 seconds (83.28% PHP - 16.72% MySQL) with 11 queries
