Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 2nd February 2005, 05:56 AM   #1
Lisandro_P's Avatar
Send a message via ICQ to Lisandro_P
Default Audio capacitors from PC powersupplies?
So, a friend of mine left a bag full of dead PSUs at my house a couple of days ago. I proceed to scavange parts from them, and promptly noticed every single one of them has a rather bigh 1uF non-polarized capacitor for filtering purposes, near the 220VAC side. I'm pretty positive they're polypropylene film caps (they look like this - not that brand though).
Are these any good as audio parts? I know some people here might faint at the mere thought of second-hand parts from a PSU in the audio path, but they seem to be quality capacitors. And the price is right
Old 4th February 2005, 08:50 AM   #2
singa is offline singa  Singapore
Send a message via AIM to singa Send a message via MSN to singa Send a message via Yahoo to singa
Hi lisandro,
If they're polyprops then it's suitable for audio except the tolerance may not be close i.e. like +/- 20 %.10% is o.k.
At the least they are polyester.Most PP's have MKP markings and MKT for polyester.Even the electrolytics are 105 degrees rated which have lower ESR than standard 85 degrees types.It does'nt have to branded types.
Old 4th February 2005, 09:21 AM   #3
pinkmouse's Avatar
Free stuff is good stuff!
Give 'em a go, you can always swap them out later if you don't like them. As singa said though, you might want to check tthe capacitance first if you are using them somewhere critical.
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 4th February 2005, 10:42 AM   #4
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
I use 'em all the time. The blocky ones are good too.
All kinds of goodies on those - medium voltage diodes, inductors, highspeed transistors and diodes, etc.
Tim
See my Electronics webpage -- the home of Vacuum Tube Drag Racing.
The key to being a successful Audiophile: "I reject your reality and substitute my own!"
Old 4th February 2005, 03:24 PM   #5
Lisandro_P's Avatar
Yes, you can get all kinds of neat stuff from those - power resistors, small sinks, fans, capacitors, inductors of all kinds, connectors, switches, diodes, transistors...
As for the caps themselves, my first thought was to use them for coupling in the inputs of the audio gear in my chain (preamp / poweramp / headphone amp). All of them are pretty consistent in value, ranging from .98 to 1.02uF. Most of them are marked "MKP" (yay!) but a few are labeled as "MEF", any idea what those are?
Old 4th February 2005, 05:52 PM   #6
Shoog's Avatar
The electrolytics in PC power supplies are about the best you can get, They have to be for this demanding role. Prity much anything you will do with them will be like a retirement in an old peoples home to them. Also the 200-250V ones can be used in tubes power supplies, if stacked.
Shoog
Old 4th February 2005, 09:10 PM   #7
Sch3mat1c's Avatar
http://www.google.com/search?q=MEF+capacitor
Appears to be metallized (self-healing) polyester (mylar) film, noninductive construction.
Tim
Old 6th February 2005, 02:10 AM   #8
just another
wintermute's Avatar
Default Just a thought
If you have access to an ESR meter might be a good idea to test them before using.
Only say this because my VCR has a SMPS which died. turned out to be a 1uF 450V electro that had died, replaced it and all was well again So I'm guessing that it could be a common part to die, and since these PS's are dead..........
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 7th February 2005, 03:13 AM   #9
sivan_and's Avatar
Send a message via Yahoo to sivan_and
I used to buy New PC SMPS just for components..
I fully agree with Shoog,Lisandro_P,Sch3mat1c.....
Even Ferrite torroid cores/ Inductors can be found in old PC motherboards, Which can used for Buck type SMPS/Swiching battery chargers..uses are infinite....
SivanandBalan
Old 13th February 2005, 05:20 AM   #10
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
Lots of quality stuff are available in an old PC SMPS.Low ESR caps,Schottky diodes, toroidal inductor,etc. I used to have lots these junk,before i cleaned 'em up after graduated from high school.Some are really good for audio,but some only just "looks good" for audio. For example,the much debated fast recovery rectifier for 50Hz app. issue.Anyway, u get many componenets for a much cheaper price.So,PC SMPS is still "audio friendly",if u agree with me!
Note:the 1 uF capacitor is for primary side snubber network.In my country,lots of them are polyester type.
Where to find PowerSupplies MotoMan_Yz400 Chip Amps 37 16th February 2008 06:49 PM
Anything I can use for DIY amp from PC powersupplies? havix321 Solid State 49 6th November 2004 02:25 AM
amplifiers with regulated powersupplies........? tbla Solid State 11 31st May 2004 01:30 AM
Major Noob question about powersupplies. Hybrid fourdoor Chip Amps 22 2nd August 2003 08:38 PM
laptop powersupplies ? iceman Chip Amps 8 2nd July 2003 09:46 AM
Page generated in 0.10282 seconds (81.84% PHP - 18.16% MySQL) with 10 queries
