| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Hello,
Building my own S&B TVC volume control. Was looking at Tom1356's Maple fittings for his pre-amp from the S&B Build thread & reading Morgan Jones Build a Valve Amp... saw the Trampoline suspension. Would it be beneficial, neutral, or detrimental to suspend the TVC's in a lattice of elastic? (All 3 axis to prevent them from falling out during moving) And, where can I get some Knicker Elastic? What the heck is it? Is there a substitute? (Google was very informative of many things you can do with it, but not where to buy some) Another alternative would be use some Dyneema line that I have, more than strong enough, just non-elastic. Thx |
#2 | |
Aerodynamics are for people who can't build engines. Enzo Ferrari |
#3 | |
#4 |
Bwahahaha... the jokes begin
Seriously though, Morgan Jones seems pretty specific here, I assumed it was for some part of undergarmets, but "Knicker" seems very... European, wondering if us North Americans call it something different I'm assuming it's designed to be close to the body (so 37șC & some humidity) probably means it would survive being inside an amplifier. Also, I wonder if this Knicker elastic has a strong elastic deformation zone, with great resistance moving into the plastic zone (i.e. permanent deformation). I don't want my TVC's to sag .I can just see friends asking me why I'm sad , replying "My TVC's are sagging, my knicker elastic just wasn't strong enough"In this Thread EC8010 talks about suspending speakers using Knicker Elastic. Other suspension 'webbing' or 'line' suggestions are most appriciated. |
#5 |
I believe the correct term for this stuff is actually "milliner's elastic", so it's for holding hats on. There are various different types, and the stuff that is similar to that used in knickers is about 1mm diameter
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference... |
| What makes an amplifier "bright", "warm", or "neutral"? | JohnS | Solid State | 51 | 13th December 2009 06:42 PM |
| What makes Nichicon "muse"/"for audio" caps different ? | percy | Parts | 2 | 3rd October 2009 05:53 PM |
| What Does Fostex "Rated Input" and "Music Power" | mark02131 | Full Range | 3 | 2nd January 2007 08:31 PM |
| Some final pics of "Stacks" revisited and "Askew" with stand | Andy G | Multi-Way | 2 | 3rd February 2005 06:07 AM |
| Anyone used Scan-Speak's "Flow Resistors" or "Aperiodic Vents"? | Ignite | Multi-Way | 3 | 18th November 2001 08:42 AM |
| Page generated in 0.09932 seconds (74.40% PHP - 25.60% MySQL) with 10 queries |
