Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 29th January 2005, 11:42 PM   #1
Mikelo is offline Mikelo  Antarctica
Default multimeter loading circuit?
Following the manual I tested voltage between two test
points with my multimeter in a CD transport circuit (CDM 4/19)
and smoked a resistor that is used as a fuse in the power supply.
I double-checked with folks familiar with the circuit and it seems I
didn't do anything wrong in where I placed the probes etc.
My hypothesis is this. My multimeter (Sperry DM-4100A)
has a relatively low impedance (1M) and although this has
not been an issue in the tube equipment and speakers I
usually work on, it was too low for this CD player circuit and
so I loaded the circuit too much with this meter.
Is this a plausible explanation?
Old 29th January 2005, 11:52 PM   #2
BlackDog's Avatar
This may sound stupid, but are you sure you didn't have your meter switched to measure current by accident? - This equates to a dead short.
One of the meters I have measures current (upto 200mA) using the same probe inputs as voltage & resistance. In the past I have picked the meter up and forgotten to check the settings....if you're lucky it just blows the fuse in the meter.
Steve
Old 30th January 2005, 12:35 AM   #3
To measure current you have to change the probes on
my meter and I hardly ever measure current directly.
It was definitely set for VDC in the lowest range.
(I was looking for 50mV.)
Old 30th January 2005, 05:29 PM   #4
your multimeter is high impedance cf. the moving coil type that were struggling to get above 20kohms/v.
More likely you shorted between 2 tracks.
regards Andrew T.
Old 30th January 2005, 05:57 PM   #5
You must be right, but I am still
struggling to find out how I did it.
I was careful and it was easy to avoid
other contacts. The only thing I did
that was different was hold the probes
there longer than usual -- maybe 5 or 6
seconds.
Thanks for your patience!
Multimeter??????? genmin Equipment & Tools 4 22nd January 2009 11:30 PM
Anode Loading Vs. Cathode Loading ? valveitude Tubes / Valves 19 22nd July 2005 10:00 PM
Page generated in 0.07528 seconds (71.02% PHP - 28.98% MySQL) with 10 queries
