| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
So I am about to renovate some old gear that I have and have a question regarding power caps that I hope some of you can give an oppinion about.
Caps have different sounds - on that I think most of us can agree, but assuming I want to keep the particular sound can I still improve it? I am thinking of changing caps to similar brand, but higher voltage - so ex. instead of 4700uF 50V I would use 4700uF 100V, but otherwise identical model. Can someone tell me pro's and con's on doing that? Remember that someone stated that power caps are better the closer your running them to the limit, but I also recall someone saying same value higher voltage will be better... So any view points? |
#2 |
I dont remember reading anything about too high voltage caps sounding better, was it some sorta discussion, or just a random comment? Someone posted a link where too high voltage caps were criticized, but I think that was bull..
You can go for higher capacitance, and add some bypass caps, that may or may not help. btw what is the voltage they are running off? It is not good to run caps at or above their rated voltage, life can be lowered, and they may heat, etc. |
#3 |
Thomas
The question was more a general question, than a specific cap value. The thing is that changing from one brand to another is really a whole different bucket of worms. |
#4 |
provided you have sufficient margin between actual voltage and maximum recommended working voltage then imo you will gain no sound improvement by increasing the caps wv. There will be a small improvement in leakage but this is unlikely to affect sound quality. regards Andrew T. |
#5 |
Ok - so just to be absolutly clear - is there a recommended degree of usability on caps in general..?
F.ex. 80% of rated voltage value? |
#6 |
DIY !
will be a 10-20% safety margin on psu-caps, maybe closer on regulated supplies.
As DC-blocking caps; for electrolytic(bipolar) in line-level, my experience is that a 10-16v cap often sounds better than a 100v. And opposite with film-caps. Arne K
Ars longa, vita brevis |
| PSU Capacitor question | Cloth Ears | Chip Amps | 11 | 17th January 2010 11:56 AM |
| Capacitor Question... | SigloOne | Tubes / Valves | 15 | 3rd May 2009 06:39 PM |
| Capacitor question... Again and again... | Dxvideo | Chip Amps | 14 | 9th January 2008 08:27 AM |
| capacitor question | crippledchicken | Solid State | 3 | 31st October 2007 09:12 PM |
| Capacitor Question | audiodumb | Car Audio | 15 | 22nd June 2005 03:49 PM |
| Page generated in 0.07893 seconds (74.83% PHP - 25.17% MySQL) with 10 queries |
