Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Creating new PCB Contacts
Old 29th January 2005, 07:07 PM   #1
bazooka is offline bazooka  United States
Default Creating new PCB Contacts
Hi, I'm pretty much a complete noob when it comes to electronics. So this shouldn't be too difficult a question for you guys.
I was trying to solder a wire to a PCB contact (y'know the tiny round silver bits with the hole in the middle). Made a mistake and the solder ring around the hole lifted right out. Now there is only a hole there.
Question is, how do I connect a wire to it now that the solder contact is gone? Or how do I make a new contact?
Old 29th January 2005, 07:20 PM   #2
Netlist is offline Netlist  Belgium
diyAudio Moderator Emeritus
Netlist's Avatar
Like this:
You can scratch a bit of the isolation from the route where the 'ring' was. The result is blank copper where the new solder will happily stick on. Ply the leg of the component as close as possible to the PCB.
/Hugo
Old 30th January 2005, 10:45 PM   #3
BrianDonegan is offline BrianDonegan  United States
BrianDonegan's Avatar
...and lower the heat of your soldering iron.
Creating new PCB ContactsHide this!Advertise here!
Switch contacts for HV supply ThSpeakerDude88 Tubes / Valves 4 30th March 2008 03:50 AM
Mercury wetted relay contacts stadams Everything Else 5 7th June 2002 03:56 PM
Copyright ©1999-2017 diyAudio
