| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Im looking for a rocker/slide - switch that will switch:
[on-on-off] no momentary! They should handle no less than 1A 230VAC I have searched all possible sources without success, anyone that could help me? |
#2 |
You must not have tried NKK Switches
For ALL your switch needs. You want a slider? You want a rocker? You want a pushbutton? a toggle? illuminated? panel sealed? They also have a good printed catalog.
Jesus loves you. |
#3 |
Stocker:
I have searched all possibilities here in sweden, and now the search has started outside, i have checked digikey and farnell without success. The switch is supposed to sit on the side of the cabinet, so as low height (parts sticking out) as possible is what im looking for. Rocker/slider anyother type, just as discreat as possible. Im going to check their catalouge thank you. |
#4 |
Are you really looking for [on on off] and only that? Is that what is making your search difficult? Is there some reason you cannot use [on off on]?
Aerodynamics are for people who can't build engines. Enzo Ferrari |
#5 |
digikey carries NKK stuff... I found the link to the NKK website through digikey's supplier info page, which I found in Google.
Jesus loves you. |
| switch-on, switch-off sequence for preamp/amp | cbutterworth | Tubes / Valves | 1 | 2nd March 2007 12:41 PM |
| Never try to switch 450V DC at 3A with a conventional mains switch... | Eva | Power Supplies | 28 | 1st November 2006 09:24 AM |
| Main on/off switch for amp using a piezo switch | using_e | Solid State | 13 | 20th June 2006 05:55 PM |
| are pc mic's... special? | Sillyboy | Everything Else | 3 | 19th June 2006 02:32 AM |
| Using a momentary switch for main power switch? | FullThrottleRic | Parts | 9 | 25th June 2002 08:23 PM |
| Page generated in 0.09256 seconds (76.05% PHP - 23.95% MySQL) with 10 queries |
