Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 26th January 2005, 08:42 PM   #1
Rody is offline Rody  Hungary
Default HA12017 - SIP-8 packaged Opamp
Can somebody tell me the pinouts of a SIP-8 type opamp? To be more specific: the HA12017.
This thing is almost impossible to find, and i'd like to replace it with a OPA134.
The problem is that i dont know which pin is wich.
On the schematic the HA12017 has pin6 for IN+, pin7 for IN- and PIN1 for OUT, but i dont know what 5 and 3 do, possibly offset pins?
Another general question: Is 4.5 volts enough for opamps, or should i feed them with 9 volts? For example the TL072.
Sorry for my "english"
Rody
Old 27th January 2005, 08:18 AM   #2
this is the circuit, where the HA12017 should be replaced. Maybe this helps. what is pin 3 and 5?
Old 27th January 2005, 08:28 AM   #3
Netlist is offline Netlist  Belgium
Netlist's Avatar
Try here:
http://www.datasheetarchive.com/
/Hugo
Old 27th January 2005, 10:32 AM   #4
I've found it! Now i only have to figure out how to replace it.
Thank You!
Rody
Old 27th January 2005, 06:28 PM   #5
Uhhh.. God knows i've tried, i'm just not too much experienced in this. I dont know how to replace the opamp, cause the HA12017 seems like a much more different construction, and i cant do anything with pins 3 and 5, the OPA134 dont have such functionality. So propably, i would have to change the resistor and capacity values nearby, and to redesign some parts, and this is too much for me. (Ok i know, i should have started with an easier project, but this equalizer looks very interesting)
Some help, or some "how-to" links would be appreciated...
thanks.
Rody
Help! 2sk389 soic packaged bettersimple Parts 3 28th April 2007 10:48 AM
Single supply opamp - unequal rail voltage and opamp selection Hans L Parts 8 19th February 2006 02:15 PM
Discrete Darlingtons vs. Packaged Darlingtons rtarbell Solid State 5 18th January 2006 02:53 PM
Regulate the psu of a power opamp with a similar power opamp? Franz G Chip Amps 34 19th October 2004 10:49 AM
Page generated in 0.08220 seconds (73.90% PHP - 26.10% MySQL) with 11 queries
