Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
input Capacitor, what will work best?
Old 26th January 2005, 10:48 AM   #1
pjpoes is offline pjpoes  United States
Send a message via AIM to pjpoes
Default input Capacitor, what will work best?
Ok so Im building the Tangent soft MINT headphone amplifier for my brother. He bought the parts and purchased a bunch of wrong parts, since Im reordering stuff, I thought I would upgrade some of the parts that looked sub-par. Apparently this headphone amp needs input capacitors. I have to imagine that better quality capacitors will improve things here, since generally this setup is dreaded for SQ. The value is 1.0uf at 100vdc or so. This current type is a panasonic metalized poly cap, I believe. I was considering a WIMA type maybe, but wasnt sure if an even better option existed. I wasnt even completely sure what to look for. My part size limit is 13mmx6mm with the pins being 10mm apart. Though I would be limited with the box types, I have been wiring esoteric resistors into this, so I can be creative in my mounting if needed.
Old 26th January 2005, 10:30 PM   #2
no help? Come on, there has to be something. Are wima's a good choice? A little confirmation would be nice.
Old 26th January 2005, 11:53 PM   #3
Nisbeth is offline Nisbeth  Denmark
Nisbeth's Avatar
You don't need 1uF for that position. If you use the parts values in the schematic you can get away with an input cap of 220-330nF (220 is the default value). The size is a problem, but an MKP (metalized polypropylene) should do the trick. I personally use one from Rifa, but honestly I don't think it's much better (or worse) than the Wimas or Panasonics. If you're sure the one you have is polypropylene, you might as well stick with that
BTW, the Wima's are only "exotic" or "botique" in the US. In Europe they are pretty common and usually available from even "around-the-corner" type stores
/U.
Old 27th January 2005, 01:17 AM   #4
well, Wima is relativly readily available here too, I mean, they are sold through most electronics wharehouses. I just assumed they were liked for there better sound more than anything.
Would going with a smaller value improve the sound of the unit, or no? I wasnt quite sure what you were saying about that. If you think the panasonic would be just fine, maybe I will start with that, and get some others to experiment with.
Old 27th January 2005, 01:36 AM   #5
tool49 is offline tool49  Canada
tool49's Avatar
Hi, I've used those panasonics metalized polypropylene caps before (those suggested by Tangent) and they offer good quality for the money. I often replaced them for Solen or AuriCap that cost 10-15 times more for little to no improvement.
This comment is very suggestive and not so objective, but it is my opinion that I would first try it that way and change it later if need be.
Hope this helps!
Sébastien
Old 27th January 2005, 02:35 PM   #6
Hey thanks, by the way, what you meant to say was Subjective rather than objective. Suggestive would mean you are implying something to me, such as, without being direct, that I should use the panasonics. HOwever, I think what you meant to say was that, its your opinion that the panasonics are good, rather than it being proven through some sort of test. Subjectivity basicly refers to the role of interpretation by humans, expanded interpretation of measurements, and possible role that say theoligy or mysticism plays into something.
Old 27th January 2005, 02:40 PM   #7
tool49's Avatar
Yeah exactly, subjective, not suggestive (English is not my first language )
Thanks,
Sébastien
Old 31st January 2005, 03:10 AM   #8
EchoWars is offline EchoWars  United States
EchoWars's Avatar
The Panasonic metalized polypropylene caps are very very good caps...I do not consider using them a compromise in any way.
input Capacitor, what will work best?Hide this!Advertise here!
Input capacitor Triox Solid State 92 5th August 2014 08:44 PM
Input Capacitor otherside Chip Amps 26 20th January 2010 03:32 PM
Will these work as input selectors? 240z4u Parts 5 12th October 2007 10:13 AM
Input Capacitor Shaz Chip Amps 3 20th September 2003 06:39 PM
P3A Amp: Input Capacitor C1 dine1967 Solid State 4 3rd February 2003 12:46 AM
