Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 25th January 2005, 08:06 PM   #1
12 Cents's Avatar
Default Siemens MKV makes noise when shaken
Hello,
I have two Siemens MKV caps here, each of them making a little sound somehow like a can of coke when I shake it. Is this normal? They are B25834-K6475, Non-PCB, date code seems 11.94.
luke
Old 26th January 2005, 10:10 PM   #2
Bernhard's Avatar
They are filled with oil.
Old 26th January 2005, 10:41 PM   #3
12 Cents's Avatar
ok, but somehow I thought they would be filled completely...? But ok maybe this is just normal production procedure.
luke
Old 27th January 2005, 01:27 AM   #4
djmiddelkoop's Avatar
this is the simple procedure to identify if unknown can-shaped-capacitors are oil filled.
Dick.
Music is the best F.Z.
Old 27th January 2005, 09:48 AM   #5
Bernhard's Avatar
Dick.
Not really, some have a thick & greasy oil, MKV is very liquid...
Old 21st February 2005, 06:12 PM   #6
12 Cents's Avatar
Default PCB in Capacitors
BTW, I really like them as coupling caps.
But what should I do with MKV's that don't have the Non-PCB label? Can the PCB "dry out" of the cap causing desease? Shall I evacuate the house and call a specialist in the case that they explode??
Noble potmeter makes noise klitgt Parts 0 20th February 2006 02:42 PM
My amplifier makes a buzzing noise Jimmy154 Solid State 7 25th October 2002 05:27 AM
Page generated in 0.10191 seconds (66.15% PHP - 33.85% MySQL) with 10 queries
