Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 25th January 2005, 04:51 AM   #1
Mr Teal is offline Mr Teal  Canada
Default Speakon Connectors
Does anyone know if the different poled versions of Speakon connectors are compatible? IE, can I have an 8 pole Speakon cup at the back of my amp with 4 channels hooked up to it, and use a 2 channel, 4 pole connector (just using two of the 4 amplifiers)?
Old 25th January 2005, 08:04 AM   #2
Nisbeth is offline Nisbeth  Denmark
Nisbeth's Avatar
AFAIK (but I'm not sure), the 2- and 4-channel versions are compatible, but the 8-channel plug is larger and will not fit in a 2-or 4 pole socket. Hvae you checked Neutrik's site for information of this? (the mechanical drawings will confirm if I'm right )
/U.
speakon to RCA help joka22 Solid State 11 15th July 2007 04:08 AM
Replace old spring-loaded amp speaker connectors with binding posts or speakon tlparker Parts 20 17th February 2007 07:32 PM
Speakon Na4lj wotsascott Parts 3 7th July 2006 04:42 AM
Neutrik Speakon connectors timo Multi-Way 7 27th August 2002 05:47 PM
Page generated in 0.06304 seconds (65.29% PHP - 34.71% MySQL) with 10 queries
