Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 24th January 2005, 09:19 PM   #1
jives11 is offline jives11  Europe
jives11's Avatar
Default filtering switched mode PSU for SI 5066 amp supply
I have a sonic impact 5066 mini amp (see under Class D discussion - subject "$30 amp" ), intending to use it to power some RS LX5 speakers connected to my sons PC,rather than the standard powered speakers for PC's.
It works and sounds pretty good using a 12v supply I found in a drawer. I'd like to power the amp off of the PC ATX PSU. You can get a card which occupies a PCI slot on the back of the PC which provides 12Vdc socket you can use to power external devices.
This basically taps a spare 12v supply from the PC switched mode., at up to 5 amps I believe.
I'd like to use this to power the SI mini amp as :
1) I don't want more wall warts
2) If I use a PSU on the PC the whole thing gets powered up/down with the PC.
Now I understand that as a by product of how the work Switched mode supplies generate a lot of noise.
Q: Is there a way of filtering out the noise ? or at least improving it ? for example cascaded ceramic caps of decreasing value i.e 0.01uf,0.001uf,0.0001uf
I know that these amps sound best when powered from Linear or battery supplies but sometimes you have to compromise.
many thanks
PFC Switched-Mode Power Supply N-Channel Power Supplies 57 13th June 2005 07:56 PM
Switched mode power supply MMicke Car Audio 3 19th February 2005 10:42 AM
Switched mode power supplies Magura Parts 13 3rd January 2004 05:44 PM
Switched mode PSU - parts? miguel2 Parts 1 26th September 2003 03:48 PM
Switched Mode vs Linear Power Supply royalmp2001 Solid State 4 12th July 2002 08:04 PM
Page generated in 0.06805 seconds (69.49% PHP - 30.51% MySQL) with 10 queries
