| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Hi everyone!!
I'm having problems getting BC327-40/BC337-40. Anyone knows a good replacement? Thanx. |
#2 |
Electrons are yellow and more is better!
This is a very ordinary transistor but with a bit more current than usual. I doubt though that this is an important parameter.
You can replace these types with almost any transistor but if you explain more where in the design they are I can give you a more precise recommendation. The "40" suffix means hfe more than 400 which could be tricky to find but it's not for certain that you need this. I have a bunch of BC550C and BC560C which may fit. C = "40"
/Per-Anders (my first name) or P-A as my friends call me |
#3 |
Hi peranders,
The transistors will be at the output of the ELEKTOR discrete opamp. Do u think the BD139/140 is overkill for that? Udi. |
#4 |
BC550/560 will probably work OK but BD139/140 is also OK. Check this for inspiration.
337 can take a bit more current but I doubt that this an issue.
#5 | |
How come the 327/337 can take more current than the 139/140?? 327/337 are rated 500ma while the 139/140 are 1500ma.. And if I'm using the 139/140 do u think I'll need to bias them harder than the 327/337? Udi. |
#6 |
BTW. You have some really nice projects on your site..
#7 | ||
I see no problem to use BC550/560 though, 15 mA => 225 mW => not too much
#8 |
Thanks..
#9 | |
current capability should be a plus? If I use the BC550/560 instead of the originals (BC327/337) than I'll have less output current, am I wrong? so why using weaker transistor will not cause problems? Maybe It's my english (that is my second language), but when u say "can take" a bit more current, you mean more driving capabilities, right? Udi. |
#10 | |
| 2sd1213 replacements | shagone | Car Audio | 2 | 28th May 2008 12:45 AM |
| replacements | doktor | Solid State | 8 | 10th March 2008 12:11 PM |
| RAYT7649 IC replacements | mmerig | Parts | 4 | 21st March 2006 06:09 PM |
| PCM1800 - replacements? | NUTTTR | Digital Source | 0 | 3rd November 2004 09:49 AM |
| Spice model for BC327 needed | angshudas | Parts | 3 | 11th November 2003 10:09 AM |
| Page generated in 0.10331 seconds (82.17% PHP - 17.83% MySQL) with 11 queries |
