| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Did it Himself
I think pinkmouse recommended a company in the UK a while ago, but no matter how much searching I do I can't find the post, so here I go.
Can pinkmouse or anybody else remember the company name? Please do not suggest I buy from Maplin. I do not like to be sent returned/damaged goods sold as new/fullprice
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#2 |
Racks, or rackmount cases?
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#3 |
Did it Himself
![]() Rackmount cases for amps etc. 1U and 2U.
#4 |
richie00boy,
I'm sure this isn't what you wanted to hear, but I have bought 4 of the Maplins cases, and each has been execellent quality. Maybe it was just a bad one you were sent? However, I agree, the business could be run alot better! Gaz |
#5 |
Two companies we used to use for commercial quantities, but they may well do small orders:
http://www.ecelectronics.co.uk/ http://www.okw.co.uk/ Or the usual Rapid, RS, Farnell etc.
#6 |
Did it Himself
Gaz,
I'm glad you are happy. I have no issue with the quality of the cases in themselves. They are also about the cheapest I could find. I just hope that you did not buy any 2U ones in the last few days, else you would probably have got my rejects. Basically I bought a 2U and 1U. The 1U was showing in stock at the time, but was actually not. The 2U arrived in short time after a receiving a battle wound from the courier. Fortunately the damage was minor and was just paint scuffing. However, seeing as the damaged face would be on display with other smart equipment and the insides would be really quite expensive, I did not see why I should suffer this. The case was returned to Maplin who disputed the damage. They eventually conceded and agreed to supply another case, but as I had written the returns number on the box and they wanted to put the item back into stock for resale they wanted me to swap boxes with my replacement case so that the fact that the item had been returned would not be obvious! When the packer swapped the new case, they noticed that one was damaged as well. Apparantly that was the last of the stock, despite the website showing to the contrary. I then wanted to cancel the order whole order as I can no longer trust Maplin. However, you cannot cancel an order once it has been placed, so they sent me the 1U case anyway dispite my protestations and not even having paid for it yet. Then I have to return the 1U case and get a refund. That will be an unnecessary trip to town for the Post Office for me, then. I have a friend that works in the head office at Maplin and the stories I hear from him just beggar belief as well. At least I can take comfort knowing that mine was just a very minor Maplinisation. Sorry for the long post/rant
#7 |
I have gone through this #$@*&^% when building mike preamps. as I have had to build custom size boxes to hold all the hand wired tube citcuits. You need a 17" by 12" by 2-7/8" box so the top plate screws clear. It is really weird that none of these companies can measure old gear and see that there has to be clearance for the screws...
Mouser electronics. They can mail anywhere I am using; Hammond # PBA19003BK2 for a 3.5" front plate # 144-32 fr a 17 by 10 by 3" box and they have a top plate. They box is too thin but works fine. They made it in such a way that it is stiff enough. This is about $35.00 or so... |
#8 |
RS components have loads of rack-mount cases and accessories.
#9 |
Did it Himself
Thanks. I know all the 'usual suspects' like RS and Farnell, CPC, Rapid, etc., just hoping for a gem that I may have missed! Unfortunately everywhere is 25+ percent more expensive than Maplin.
#10 |
Did you try EC and OKW?
| Equipment racks to floor & TT to wall - best de?coupling/ interfaces | rick57 | Everything Else | 0 | 25th September 2006 02:10 PM |
| Your Thoughts on Racks & Stands | HipoFutura | Solid State | 5 | 25th July 2006 12:17 PM |
| DIY equipment racks | Marlowe | Everything Else | 1 | 16th January 2006 11:26 PM |
| Passive Radiator system with 2x10 inch and 1x15 inch | Lach O'Sullivan | Multi-Way | 3 | 13th September 2003 03:29 PM |
| Page generated in 0.11493 seconds (80.44% PHP - 19.56% MySQL) with 10 queries |
