| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Hi!
I´ve got a big tranny (450VA) for a powersupply! The Secondary voltage is 15V each. There are 6 ![]() secondarys! The question is: What to to with the unneeded secondarys? confused Parallel it (with correct polarity, to lower resistance?) or leave them unconnected? Any suggestions, please! Best wishes from Germany!
#2 |
You can parallel them with good result (adding more current each time), however you need to make sure that they are all in fase when paralled.....
Free Schematic and Service Manual downloads www.audio-circuit.dk, Company: www.dupont-audio.com, Joint venture: www.DupontMantra.com |
#3 |
Thanks!
That were my thougts, too. I was just wondering, because the lable only mentioned 2 Secondaries with 15V each (one is red- yellow and the other is blue- green) Those windings exists 3 times each! Bye, dobbeln |
#4 |
or you could series link the secondaries giving 45Vac. or parallel 1 pair at 15Vac and series the last at half current to give 15Vac hi current and 30Vac @lo current. regards Andrew T. |
| What makes an amplifier "bright", "warm", or "neutral"? | JohnS | Solid State | 51 | 13th December 2009 06:42 PM |
| Parallel secondaries | barendh | Parts | 14 | 15th April 2007 02:13 PM |
| Say Hello To "Sparky" the Parallel Chipamp | lgreen | Chip Amps | 13 | 25th June 2006 03:58 PM |
| Some final pics of "Stacks" revisited and "Askew" with stand | Andy G | Multi-Way | 2 | 3rd February 2005 06:07 AM |
| ? on secondaries of a tranny | JazzzSpazzz | Parts | 13 | 21st April 2004 05:58 AM |
| Page generated in 0.06680 seconds (72.19% PHP - 27.81% MySQL) with 10 queries |
