Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 19th January 2005, 01:39 PM   #1
KT is offline KT  United States
Default Jack Elliano/ Electra-Print TX based preamp
Does anyone know about the transformer based preamp from Jack Elliano/ Electra-Print that's in the current issue of audioXpress?
It uses two $56 step-up transformers and a log taper pot (10k, I believe).
I wonder how this compares to something like the TX-102.
Best,
KT
Old 19th January 2005, 03:51 PM   #2
Apex Jr is offline Apex Jr  United States
I displayed in the same room as Jack at THE Show in
Las Vegas and there were alot of people looking at those amps.
You can call Jack at 1 702 396 4909 and I'm sure He'll
give you all the information you would need .....
Steve @ Apex Jr.
Old 19th January 2005, 04:34 PM   #3
Steve Eddy's Avatar
Default Re: Jack Elliano/ Electra-Print TX based preamp
One thing you need to be aware of is that the thing has an exceedingly low input impedance. With a 1:8 turns ratio and a 10k pot, you're looking at something on the order of just 150 ohms or thereabouts which is going to limit the source components you'll be able to use it with.
Also, cap coupled output stages, which are intended to drive much higher load impedances may need to have the coupling capacitance increased to avoid unacceptable low frequency rolloff.
se
Electra-Print 300BDRD Salsero Tubes / Valves 9 11th July 2009 06:37 PM
Anyone compared electra-print SE:PP interstages to electra-print PSA-2 autoformers zobsky Tubes / Valves 0 11th June 2009 05:39 PM
FS: Electra-Print 10H choke 5u4 Swap Meet 2 28th May 2008 02:41 PM
Electra Print -passive volume preamp. felixx Solid State 5 3rd October 2007 10:08 PM
Electra-Print transformer based passive preamp. franjy Parts 0 19th September 2005 03:35 PM
Page generated in 0.07686 seconds (69.21% PHP - 30.79% MySQL) with 10 queries
