| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Did it Himself
I am looking at the 'peak reverse current vs. di/dt' and 'recovery charges vs. di/dt' graphs on a fast recover diode datasheet. How do I tell what is a good one and a bad one? Surely there should be some kind of graph with a time axis?
#2 | |
For same species devices, the lower the Irm, the better. Caveat: if the stored charge, Qrr is much larger,, it will just take longer for the device to entirely shut off. The two do not relate absolutely directly, you can have lots of stored charge with a low Irm, and vice versa. So, lower stored charge is also better. Some devices will use recombination to lower either thing, but that usually comes with a price, reverse leakage temp sensitivity being the major thing, which can lead to high temp runaway in a switcher.....(blowed up). Some datasheets show a time based graph, but it is just a typical pic showing what the terms mean, when the device is tested in a standard setup. Cheers, John... (did I answer your question?) |
#3 |
Did it Himself
Thanks for the great reply. I think I understand
EDIT: I must have been looking at the datasheet late at night. Having gone back to look again following your new info I see a graph of time vs di/dt on the previous page
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#4 | |
In the old days, it was the old trr test setup, and darn near every diode manufacturer made hugely sloppy test rigs to see it..The databooks drew this rounded waveform thingy, with slow recovery to zero current...hand drawn, of course, because the actual scope photo typically had these huge overshoots and ringing..the manu's were embarrassed to actually print the waveforms..(I worked at two manu's). Back in '81, I build this rig that measured 2 nSec diodes accurately, showing turn offs as fast as 250 picosec without overshoot, and it allowed the diffusion guru's to develop ways to soften the recovery on their 15 nano product. Back in '83 or so, they started using that inductive di dt test setup, as the fast power devices couldn't be read accurately, and most designers had inductive switching circuits anyway..but it still doesn't make it easy to figure out.. Cheers, John |
| schottky vs. soft/fast recovery diodes | metebalci | Parts | 26 | 24th October 2010 05:29 AM |
| Reading and interpretting various graphs correctly! Unconfuse me! =) | wigginjs | Multi-Way | 7 | 6th September 2007 06:53 PM |
| Fast soft-recovery controlled avalanche rectifiers? | quantran | Parts | 6 | 5th May 2007 04:16 PM |
| Fairchild Stealth soft recovery fast switching diodes | KevinLee | Swap Meet | 3 | 10th January 2006 09:53 PM |
| Ultra Fast Diode Bridge. | bigparsnip | Swap Meet | 173 | 20th June 2004 09:32 PM |
| Page generated in 0.08242 seconds (75.80% PHP - 24.20% MySQL) with 10 queries |
