Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 11th January 2005, 02:21 AM   #1
Default Electrolytics have flat sides?
I've just finished stripping my CNC lathe for it's retrofit and was giving the power supply a clean.
I noticed the massive 100V 10,000uF smoothing capacitors looked as though they've been hit on the side as some point. I remembered seeing this in a few pictures of big electrolytics.
Once I had the capacitors free of their clamps and was cleaning them off, I realised that the sides have purposely been flattend to form three flat surfaces on the capacitor.
Why might this be?
The only things I can think of are to make their production simpler in some way or to stop them rolling around if mounted horiztonally.
If it was done after the capacitor was rolled, it'd almost certainly damage the layers. Which means the cans must have these surfaces formed before the capacitor is installed. This must significantly reduce the available volume of can by comparison with modern day electronics, not only because the can is being squashed smaller, but the capacitor that it will later house is also cylinderical, so it can only have a diameter the same as the distance between two of the flats.
There's some strange in my neighbourhood! I'm arming the ectogun...
Old 11th January 2005, 07:32 AM   #2
I have seen upto six flats fromed in the sides of electrolytics extending almost the full length of the can.
My guess is it may squeeze the coil and impart a non unifrom arrangement of stress & strain and so avoid vibration??? or shift its frequency into another spectrum??.
After the coil is inserted into the can there must be a gap. Maybe this is just a method of securing the coil to reduce/eliminate movement in the internal connecting wires to improve reliability??
regards Andrew T.
Old 11th January 2005, 12:02 PM   #3
I've seena number of bigger electros with various types of "forming" on the sides. My guess its to increase the strength of the can.
Because it times the capacitor can my become a preasure vessel.
How Flat is "Flat"? (XT18WO + 27TBFC-G = MTM) zenon Multi-Way 3 21st January 2007 03:15 PM
2- 1/2 value inductors on + and - sides DaveThreshold Multi-Way 7 8th August 2006 11:40 PM
Enclosure w/ curved sides, need your help MITMechE Multi-Way 14 1st April 2004 11:08 PM
Curved sides... Kongen Multi-Way 6 3rd January 2004 09:14 PM
NPN on both sides of the output sapito Solid State 36 22nd October 2002 11:15 PM
Page generated in 0.07996 seconds (72.12% PHP - 27.88% MySQL) with 10 queries
