Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 8th January 2005, 02:02 PM   #1
Cr3ator is offline Cr3ator  Netherlands
Default Weird fuses in Pioneer SA-510
After buying an old Pioneer SA-510 from an Ebay like website in Holland, I was very happy to hear some nice music in my room again. After a while the left channel broke down. So, I opened up the amplifier and checked the fuses. Two of them were dead. After replacing both of them, I fired the amp up with an variac to see one fuse die again immediately.
Nevertheless the amp was functioning as expected. All the lights went on, and both channels were playing music again. With one dead fuse, this is not the behaviour you would expect. I replaced this fuse once again, and saw the other one burn out! WTF?? Same thing, the amplifier was functioning. I left it as it was but would really like to know the function of this dual fuse. Anyone who has had the same experience?
See picture for more details on the particular fuses. Arrow indicates dead fuse.
ErikH.
Old 8th January 2005, 02:19 PM   #2
Netlist is offline Netlist  Belgium
Netlist's Avatar
Maybe their purpose is to protect the AC-voltage outlets on the back of the amplifier.
/Hugo
Old 8th January 2005, 03:29 PM   #3
/Hugo
They aren't used, there are no shorts and it's not always the same one that blows if you replace them. But I'll check the outlets.
Old 8th January 2005, 04:05 PM   #4
Geek's Avatar
Speaker Z too low?
Old 8th January 2005, 04:33 PM   #5
Checked: All work ok. So what we got is a perfectly working amplifier, but still one fuse missing
Old 8th January 2005, 04:50 PM   #6
Netlist's Avatar
Does the amp still work when you take out both fuses?
Where are the wires that come from the fuses lead to?
Time for a new Signature:
If it's broken and it works...don't fix it.
/Hugo
Old 8th January 2005, 05:38 PM   #7
/Hugo
With both fuses removed the amp doesn't work at all.
I like the signature I think I have to use that one for some time...
"If it's broken and it works...don't fix it."
See: here!
Old 8th January 2005, 05:47 PM   #8
Stocker is offline Stocker  United States
That looks a bit nasty inside. Hit it with some compressed air and see how it does.
Jesus loves you.
Old 8th January 2005, 05:58 PM   #9
It sure can use some cleaning, but it's a very sticky, grease like substance... Perhaps better leave it there. Even if that causes a short, how can the amp still work??
See: here!
Old 10th January 2005, 07:00 AM   #10
raypsi is offline raypsi  United States
Default fuses
I'm retired from Sears, but we used to repair lots of every brand of stereo. Stereo's of modern design used split supplies. the preamp mains would be +15vdc and -15vdc so guess what? They have a fuse for each main, plus and minus. Same goes for the outputs, that run off of split supplies a fuse for the plus and a fuse for the minus supply's
Make sure the fuse clips are clean and tight. Loose clips will cause fuse to overheat and even though you are nowhere near the current rating of the fuse the heat will blow them out.
Let nothing block the air vents on older units as they tend to draw more current with age. Capacitors become leaky, causing the supply to draw more current.
semper fi
Dumpster Dive Find - Pioneer SX-201 Blowing Fuses Wally Solid State 11 24th February 2008 12:15 AM
nad 214 where are the fuses? gregkitchen Solid State 1 18th August 2006 11:35 PM
Page generated in 0.10509 seconds (76.39% PHP - 23.61% MySQL) with 11 queries
