Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 5th January 2005, 10:57 PM   #1
Default Need some parts recomndation: some RCA connectors and power switch
Im building an 8 channel amp for my orions based on linkwitz's design. I have some questions on parts to use.
220 uF 35V electrolytic Capacitor: I was planning on using the same type used in the crossover (Digikey P10297) but I noticed the tolerance is 20%!?!?. Anything better or is 20% ok? I was thinking since I have to use 2 of these for 4 opamps they could all differ by a lot.
RCA Phono Connectors: I wanted to use some gold plated ones that I could somehow mount to a 1/4" plywood, either with a plate I can screw into the wood or the kind with the nut on the back.
Gold Binding Posts: It would be great if I could find them in pairs or individually that could be mounted similar to the RCA connectors mentioned above.
Question: If I mount 6 RCA connectors and 16 Binding Posts to a piece of plywood, will there be interfearance?
DPST Power Sitch for 10A: A I need a sturdy switch that can also be mounted as above.
If my descriptions of the mounting method didnt make sense check out Digikey Q210-ND and http://www.switchcraft.com/products/..._schematic.pdf
Old 24th January 2005, 06:48 AM   #2
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
Try Neutrik,Deltron or WBT!!!!!!!!!!
Old 24th January 2005, 02:27 PM   #3
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
Partsconnexion carries cheap RCAs and binding posts (Connex): http://www.partsconnexion.com/catalog/connectors.html
The quality is surprisingly good.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
DC power connectors? space-cake Parts 1 30th November 2006 04:43 AM
PARTS PARTS PARTS!!! Infocus Powerview 820, triplet, ballast, light, power supply!!! marioinla Swap Meet 1 31st August 2004 04:22 PM
Power connectors for external PS net-david Chip Amps 1 1st April 2004 04:44 AM
Using a momentary switch for main power switch? FullThrottleRic Parts 9 25th June 2002 08:23 PM
Page generated in 0.08081 seconds (68.22% PHP - 31.78% MySQL) with 10 queries
