| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I've got this 10A 250VAC rocker switch that lights up and theres 3 terminals marked 1,2 and 3. Is this how to wire it ?
1) will be 240VAC in. 2) 240VAC output. 3) Ground , so does it go to safety earth ? does it matter if its LIVE or NEUTRAL for the AC in ? Thanks. |
#2 |
DON'T connect any of the pins to ground - ground (earth) is for safety and sheilding, NOT return current.
First you will have to identify the terminals - numbering is at the discretion of the manufacturer. With a multimeter measuring ohms, take readings between each of the switch pins with the switch in both on and off positions. You will find that there is an effective open circuit (no reading) on one pin - this is the internal neon connection. Connect this to mains NEUTRAL. Connect mains ACTIVE to one of the other pins - if the light goes on and off when you activate the switch, it is the correct pin. If the light stays on all the time, change active to the other pin. The remaining pin is now your mains out. Switches should always be connected in line with mains ACTIVE. When doing anything with mains voltages, BE CAREFUL - 240V isn't very forgiving.... Cheers Graeme |
| what source selector rotary switch and how to wire it | bemoth | Parts | 29 | 1st February 2008 01:31 PM |
| rocker | ratso | Parts | 0 | 6th June 2007 04:27 AM |
| Rocker Switch HELP | danielduaine | Parts | 1 | 10th April 2007 11:58 PM |
| How to wire a 3 terminal rocker switch ? | Stormo | Parts | 1 | 28th November 2003 08:20 AM |
| Page generated in 0.07129 seconds (67.69% PHP - 32.31% MySQL) with 10 queries |
