Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 10th January 2005, 01:33 AM   #11
DC pops are no problem. Locate the source of the DC and either service the piece or use a DC blocking cap. Either way, the problem will be solved.
The move-from-speaker-to-speaker thing is not a problem either. Relays will work just fine, or you can handle it in the electronics. For what you are describing, I'd probably say to avoid relays--not because they don't work, but because you'll be switching thousands of times per day. Look at the number of cycles a relay can handle, then run the math. You'll start experiencing reliability problems in a few months and it will be a perpetual maintenance headache from then on.
The fade down/up on the volume can be handled either analog or digitally, but will be easier digitally as I believe they have volume chips where that is a built-in function.
Grey
Old 10th January 2005, 01:43 AM   #12
Bill Fitzpatrick's Avatar
You could do this with a 60 stage CMOS shift register and 60 FETs used as switches for the speakers. Your power requirement seem low so I think we are talking about 50 cent FETs.
The input to the shift register chain is a single pulse for which the repetition can easily be adjusted with a pot.
This solution is reliable and extra cheap. You can send the savings to me.
Old 10th January 2005, 04:10 AM   #13
A suggestion
Can't the sound directivity be generated using multispeaker arrays, instead of so many speakers...like a jet flying on a screen from one side to the other.
Gajanan Phadte
Relay based source selector. Help needed! MASantos Chip Amps 9 8th August 2007 11:28 PM
Aleph P1.7 relay attenuator help needed tvnorm Pass Labs 10 31st August 2006 01:35 AM
Advice needed for selecting a speaker relay spendorspain Solid State 8 10th December 2005 10:16 PM
Need Advice with Timer Relay Shut Off Bryan Tubes / Valves 7 25th October 2005 07:43 PM
Quick Relay/Timer Help Needed woodrufj Parts 3 24th June 2004 06:05 PM
Page generated in 0.07443 seconds (70.14% PHP - 29.86% MySQL) with 10 queries
