Want to measure µV on the scope: should I buy a new one or build a low noise preamp? - Page 3 - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 27th December 2004, 02:48 PM   #21
Electrons are yellow and more is better!
peranders's Avatar
DAC output with less than 1 uV hardly excists. It's above 120 dB S/N
PS under 5-10 uV is also pretty good.
Anyway, good luck with your preamp.
/Per-Anders (my first name) or P-A as my friends call me
PA03 LM4780 amplifier group buy, SIGN UP HERE for the group buy 0 boards left. 118 paid.
Old 27th December 2004, 03:04 PM   #22
Bricolo is offline Bricolo  France
Bricolo's Avatar
2V RMS with 96dB dynamic range is something like 30uV for the LSB
not so far from the uV
Just remember: in theory there's no difference between theory and practice. But in practice it usually is quite a bit difference... Bob Pease
Old 27th December 2004, 03:17 PM   #23
Bernhard's Avatar
What is so interesting here ?
Old 27th December 2004, 03:28 PM   #24
Bricolo's Avatar
I was just explaining that some uV aren't too precise to measure a dac
Old 27th December 2004, 04:19 PM   #25
jackinnj's Avatar
mostly power supplies, and dac outputs
for power supplies you should bandwidth limit the amplifier -- the high pass filter, consisting of the two 1000uF electrolytics and 10K resistor is 100 milliHertz, and the optional high pass filter is 10Hz.
you can make a similar differential or instrumentation amplifier from 3 low-noise opamps -- butyou need to very carefully match the gain setting and feedback resistors. The SSM2019 is about 1/2 the price of an AD797 and is, I believe, primarily aimed at the microphone amplification market.
Old 27th December 2004, 04:47 PM   #26
Bricolo's Avatar
limitting the bandwidth, but how much?
AC coupled, that's clearly not a problem
but how much for the high pass? with a *1000 gain, the opamp will limi t itself the bandwidth (with a 797+cap, max is approx 400khz, without the cap it's 100khz)
Old 27th December 2004, 08:00 PM   #27
jackinnj's Avatar
for testing power supplies -- like the super regs or the Sulzer, etc. it is useful to know the noise in the range of just above DC to 10 Hz -- for the DAC's etc. you obviously don't want to limit the upper range this low (i.e. below audibility.)
a small cookie tin is used by the folks at Linear Tech to shield their low noise power supply testing amplifier.
Old 27th December 2004, 08:50 PM   #28
Bricolo's Avatar
ok
does a cookie tin mean a cookie metal box?
Old 27th December 2004, 10:05 PM   #29
Banned
Send a message via Yahoo to Elso Kwak
ok
Yes, the one you keep biscuits in.
Old 27th December 2004, 10:07 PM   #30
Bricolo's Avatar
damn, I'll have to eat a lot of my mum's christmas biscuits to have a spare box
Can I use a scope to measure powerline noise? Saurav Equipment & Tools 31 5th January 2017 04:32 AM
How to measure JLH Class A with a Scope chris ma Everything Else 84 28th December 2012 08:13 PM
How do I measure - 140 dB noise levels? gentlevoice Solid State 23 23rd October 2008 02:39 PM
Why am I picking up so much noise on my scope? Bricolo Everything Else 54 8th June 2004 05:20 AM
Can I look for (or even measure) distorsion on an amp with a dual scope? Bricolo Parts 17 17th September 2003 02:06 PM
Copyright ©1999-2017 diyAudio
