Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 22nd December 2004, 07:22 AM   #1
antomas is offline antomas  Europe
Maître sans marteau
Default Good SMD resistors in Europe
Hi everybody,
does anyone know of good (sounding) SMD resistors that could be easily purchased in Europe from RS, Farnell, Distrelec, Shuro, etc.?
They should be as much low-noise and large as possible (1206 type?), in order to be used in a preamplifier.
Thanks very much for your help,
Massimo
Old 22nd December 2004, 11:04 AM   #2
mcs is offline mcs  Denmark
How about the metalfilm mini-melf resistors available from Farnell?
Best regards,
Mikkel C. Simonsen
My personal electronics website
Remote control kits website
Old 22nd December 2004, 09:14 PM   #3
Maître sans marteau
Hi Mikkel,
thanks very much for your kind answer. Do you mean to the BC resistors code 3087207 (and similar)?
In case, may I ask if you did try them or you just assume similar quality to other BC/Beyschlag resistors series?
Massimo
Old 22nd December 2004, 09:25 PM   #4
Yes. They are avilable in two or three different sizes, and in 1% and 0.1%.
Massimo
I have seen others recommend them (I don't remember where), and then I tried them myself. I needed some small, low noise, resistors for a mic preamp, and I used the mini-melfs. The preamp works well, but I can't really say if that's because I used melf resistors
Best regards,
Mikkel C. Simonsen
Old 22nd December 2004, 09:45 PM   #5
Maître sans marteau
Thanks very very much!
Massimo
Are these resistors good, or should I...? giacomo_pagani Parts 3 28th May 2008 02:38 PM
Where to buy Mills non inductive 5 watts resistors in Europe? supernet Swap Meet 4 14th October 2006 04:35 PM
Toshiba 3690 is it in Europe? (Or good value for money transport) Bas Horneman Digital Source 1 30th June 2004 10:05 AM
GC input coupling caps from RS (Europe): any good? antomas Chip Amps 20 27th August 2003 06:33 PM
Page generated in 0.07589 seconds (70.46% PHP - 29.54% MySQL) with 10 queries
