Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 22nd December 2004, 01:33 AM   #1
Default Capacitors - Audionote & Auricap
How many capacitors threads is enough right!?
I've been reading a lot of different sites that all say they've had good results with Auricaps for their cost.
I've also been looking around here in England and found that some of Audionotes copper foils aren't too expensive for use as coupling capacitors. Although, they're more expensive than the Auricaps.
I want to say, I'm not into spending money for psychoacoustics. I couldn't afford to use AN's silver capacitors, but their copper foils are just within my range.
I wanted to ask if anyone had ever tried Auricaps, or AN's copper foils, and if so, what they thought of them.
Old 22nd December 2004, 06:32 AM   #2
ashok's Avatar
I have one pair of Auricaps and one pair of Jensen Copper foil PIO's. I believe that AN caps were earlier made by Jensen .
I also have some Alu foil PIO caps (Jensen).
I tried them on the Gain Clone. I prefer the Alu foil types. The Cu foil type sounds smoother in the midrange but I felt it sounds too rounded off. Not particularly good for rock I guess. Maybe great for classical music.
Auricaps came out last .
Can't say how they will be in tubed circuits.
Some local PP foil types also sounded very good .
Cheers.
AM
DynamiCap / Auricap gaincell Group Buys 6 6th March 2012 01:58 PM
auricap Vs musicap (Another Cap Question) dubdub Tubes / Valves 13 1st May 2008 02:13 AM
what would you use as a bypass cap? auricap or russian PIO? jarthel Parts 8 13th June 2006 01:43 AM
AuriCap Glass_painter Tubes / Valves 14 24th July 2003 06:19 PM
Auricap, Hovland or NO Cap?[Search for the Best Cap] Elso Kwak Solid State 8 16th May 2003 05:48 AM
Page generated in 0.06958 seconds (67.64% PHP - 32.36% MySQL) with 10 queries
