Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 15th December 2004, 07:34 PM   #1
JC Fardo's Avatar
Default Resistor power rating for XO?
Hi
There´s 5 Watt and 12 Watt from Mills manufacurer, for example.
Which is best recommended for speaker crossover?
TIA
JC
Old 15th December 2004, 09:08 PM   #2
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
...How many watts is the speaker/amplifier...
Tim
See my Electronics webpage -- the home of Vacuum Tube Drag Racing.
The key to being a successful Audiophile: "I reject your reality and substitute my own!"
Old 16th December 2004, 09:04 AM   #3
JC Fardo's Avatar
Thanks Tim
80W RMS/ CHANNEL solid state
JC
Old 16th December 2004, 10:35 AM   #4
Did it Himself
richie00boy's Avatar
Firstly, it won't hurt to have more power rating than you need, unless it means going to a wirewound type which could possibly be inductive.
To work out the rating you assume a 4 or 8 ohm load as appropriate for your speaker, then just use ohms law to work out the current in the resistor at full output. Then you simply square the current and multiply by the resistor value to get the required wattage.
ohms law is V = I x R
or in your case rearranged as I = V / R
Old 16th December 2004, 07:52 PM   #5
markp is offline markp  United States
If it is in the tweeter circuit then a 12 watt Mills will be overkill. A wirewound resistor will take 10 times its rated power in a peak no problem!
If it sounds good... it is good!
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
2.7R zobel Resistor...Watt Rating? Wynand Chip Amps 12 7th October 2007 05:39 PM
Resistor type and power rating suspired Tubes / Valves 5 7th March 2006 02:52 PM
Power rating of an IGC Dr.H Chip Amps 15 21st November 2003 09:43 AM
Page generated in 0.06758 seconds (71.79% PHP - 28.21% MySQL) with 10 queries
