Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
I need to power 5x LM833N
Old 15th December 2004, 04:54 AM   #1
muhy3 is offline muhy3  Australia
Default I need to power 5x LM833N
I am currently studying computer systems engineering, and I am also an audio enthusiast. Recently I have been sketching my own circuits using the internet and books but I have many unanswered questions in my mind.
I designed a band-pass 24dB filter to use for my future 12" XLS subwoofer and now I am designing a suitable regulated power supply. The LM833 data sheet specifies a +/-15V at Vcc, Vee to power each IC.
The circuit I have found easy enough for me to build uses a 240VAC transformer to 12.6VAC @ 1.9A which has a supply voltage of 16V. If I replace the capacitors with 200uF and resistors with 23ohm I get the desired 15V. I would like to know if this circuit is suitable to use, and if my numbers are correct.
There used to be a time, when penguins filled the sky!
Old 15th December 2004, 07:14 AM   #2
Ouroboros is offline Ouroboros  England
Ouroboros's Avatar
LM833s are very similar to 5532s. The current draw for five of them will not be very high, so an easy way of getting open-loop regulated power rails would be to use your transformer, bridge and capacitors (no resistors) to give 18v or so, and then build a couple of very simple emitter-follower regulators for the + and - rails.
Each regulator would only need a 15V Zener, a resistor and a transistor (NPN for the +ve rail, PNP for the negetive rail) to give outputs of approx +/- 14.4V.
Shout if you need a schematic.
Old 15th December 2004, 07:51 AM   #3
A schematic would be appreciated very much if it's not too much trouble. Thank you for helping me.
Old 15th December 2004, 08:14 AM   #4
Ouroboros's Avatar
This is the sort of thing. Most textbooks will show something similar. This is using a CT transformer, but your half-wave system will work provided the current is low. You'll need about 18V dc on each of the input 2200uf main smoothing caps.
Old 15th December 2004, 08:33 AM   #5
Thank you for your help, sir. I will contact you as soon as I complete the power supply and tell you how I went.
I need to power 5x LM833NHide this!Advertise here!
40A 250V Schottky Power Diodes- Has anyone use in Power Amp to replace Diode Bridge? dtm1962 Solid State 10 15th September 2011 07:38 PM
smps power sg3525 for 3000 wats power alimentation MARAVILLASAUDIO Car Audio 2 24th February 2005 06:58 AM
selling high current power supply for power amps. ericpeters Swap Meet 0 14th January 2005 02:21 PM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
power output calculations, rated power and required power output metebalci Tubes / Valves 7 22nd February 2004 05:49 PM
