Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 13th December 2004, 11:03 PM   #1
darkfenriz's Avatar
Default power dissipation
how much power can i dissipate from a SINGLE transistor??
I mean to-3 case (probably best), huge (but not active) heatsink
cheers
Old 13th December 2004, 11:25 PM   #2
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Check the datasheet.
Most TO-3's are in the 50 to 150W range.
The specification states that the case is kept at room temperature (25øC), which realistically means either very short duration use (essentially pulsed) or water cooling. A large heatsink with a few hundred watts might hold 25 above 25øC (or 40 in Australia ), or 50-65øC absolute.
If there isn't a graph of it, there's a derating spec which usually goes from say, 150W at 25 down to 0W at 175øC, so say 75W at 100øC. With good thermal contact you can assume the case is the same temp as the heatsink (plus a few degrees, you should be able to find some specs for conductivity of insulators and stuff).
Tim
See my Electronics webpage -- the home of Vacuum Tube Drag Racing.
The key to being a successful Audiophile: "I reject your reality and substitute my own!"
Old 14th December 2004, 03:08 PM   #3
the highest TO3 power rating I have seen is 250w.
This is only at or below 25degrees C case temperature.
I think you could only achieve this with water cooling.
regards Andrew T.
What is power dissipation? geminni Everything Else 7 14th January 2007 07:39 AM
Q about Total power dissipation Bensen Everything Else 8 29th December 2005 10:02 AM
Need help in calculating power dissipation mclagett Everything Else 3 24th May 2004 10:52 PM
Power dissipation control byteboy Pass Labs 14 16th December 2003 05:30 AM
power dissipation Opie Solid State 6 1st March 2002 07:54 AM
Page generated in 0.06712 seconds (66.98% PHP - 33.02% MySQL) with 10 queries
