Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 8th December 2004, 06:12 AM   #1
rabbitz is offline rabbitz  Australia
rabbitz's Avatar
Default Found this amp case in Oz
Stumbled on this amp case in Australia decided to buy one.
Received it today and not shabby at all........ a very nice unit. Comes with Alps switches, knobs, IEC socket, blue LED and represents great value. Nice to find another supplier as cases are a pain to source when doing amps.
I got them to remove the lettering on the LH top corner which they did sucessfully. BTW, I'm not involved with this site but thought it was a good find.
http://www.diyfidelity.com.au/produc...products_id=35
Old 9th December 2004, 12:03 AM   #2
Jye is offline Jye  Australia
Jye's Avatar
Great case, thanks for the info.
Is the lettering on the front etched on?
Old 9th December 2004, 04:33 AM   #3
rabbitz's Avatar
Lettering silk screened on by the looks of it. They removed the LH top lettering for me with paint thinners and didn't damage the anodised surface.
Old 10th December 2004, 01:22 PM   #4
lazyfly is offline lazyfly  Australia
They're great cases. Factor in the price and they're quite brilliant. Fit and finish is excellent. The base panel is drilled and tapped out for what appears to be a production run of some sort though this shouldn't be a problem for anyone.
Jye, if you get one and want to remove the text some goofy bloke reckons Zippo lighter fluid works as well or better than thinners so you could see it first then remove it if desired.
Cheers.
I Found You! Grasp Introductions 4 12th December 2008 07:54 PM
Found these feet in case anyone is interested. Wildcard26 Multi-Way 0 6th June 2008 05:09 PM
Look what I found in my new RCD-971! pureh2o Digital Source 3 29th April 2008 07:11 PM
found DIY amp - now what? rickl Tubes / Valves 3 5th January 2006 05:09 AM
found... EDY Digital Source 1 5th August 2003 08:49 AM
Page generated in 0.07633 seconds (72.25% PHP - 27.75% MySQL) with 10 queries
