| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Hallo
is output imedance of IGBT low or high compared to bjt and MOSFET?? just starting interesting IGBTs and cannot find much practical data- only sructure theory. waiting for answers cheers |
#2 |
AFAIK, it's a BJT with a MOSFET in front of it, sorta, so it doesn't take any power to switch massively. But that doesn't explain why they are slow, they only come up to 600V (at least what I've seen at Mouser) and supposedly have NO tolerance for anything out of limits.
Don't know what kind of linearity they have, if any. Only used for switching big stuffs AFAIK... Tim
See my Electronics webpage -- the home of Vacuum Tube Drag Racing. The key to being a successful Audiophile: "I reject your reality and substitute my own!" |
#3 |
Does this help?
600V 30A IGBP You can derive the output impedance from the datasheet but the problem is that it is increasing at low Vce values, i think. At 30A the Vce drop is ~2.1 v which is about 70mohm.
Hjelm |
#4 |
thank you
i found somewhere this schematic (hope I don't harm enyone's copyright or anything) and was thinking of common emmiter or SE mode what do you think? |
#5 |
Building anything with IGBP devices is way over my head.
Although i do think the schematic is interesting especially the two feedback loops. I wouldn't consider myself competent enough to design those.
Hjelm |
#6 |
another words
do you think IGBT may work good as a follower? |
#7 |
I have read that there are special considerations required to operate IGBT' as a follower, such as you see in many amp designs. They can latch-up, due to a parasitic NPNP thyristor style construction. I saw a design once, probably in Wireless World or Electronics World, that used a biasing arrangement to prevent this occuring.
OTOH JLL Hood has used them in amplifier designs, so maybe this problem is exagerated. I would do a bit more background reading first before trying them. I see them used a lot in the latest power inverters for motor control. In that application, they appear to have many advantages, efficiency being the most obvious, in that the size has shrunk for the same power. |
#9 |
That is very probably the one I was thinking of.
#10 |
I'm just looking for lowest output impedance possible
igbts seem tempting with low emmiter resistance combined with voltage driving, don't they? |
| Balanced IGBT for amplifier output | Lazy Cat | Solid State | 164 | 4th June 2011 11:17 AM |
| 3C24 in a SE output stage - output transformer impedance recommendation !!! | aldovan | Tubes / Valves | 15 | 6th September 2008 10:18 AM |
| Can An Output Transformer Change A Voltage Amp's Output Impedance From 0.1 To 47 Ohms | kelticwizard | Everything Else | 11 | 25th March 2007 05:17 AM |
| Output Impedance? | ble0t | Parts | 4 | 19th January 2006 05:45 PM |
| Page generated in 0.08794 seconds (84.67% PHP - 15.33% MySQL) with 11 queries |
