Alps RK168 pots in Eagle?
creating parts is pretty difficult I think
Have you read the Eagle help file? It explains the procedure quite well. (For obvious reasons, a spec sheet of the pot would be helpful.)
The help file is available in PDF format on the Cadsoft website.
You will also find an app note there that deals specifically with the creation of library devices (I haven't checked that file out, though, so I can't comment on it).
Good luck.
